I guess it was the 820-s I wondered about in post #1550795
Search Results for fl820s
Part Number Manufacturer WIX Part Number
FL820S MOTORCRAFT 51372
zoom
Part Number: 51372
UPC Number: 765809513723
Principal Application: Ford/Lincoln/Mercury (91-09), Mazda (00-09), Cadillac STS-V, XLR-V (06-09)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.167
Outer Diameter Top: 3.668
Outer Diameter Bottom: Closed
Thread Size: 22X1.5 MM
By-Pass Valve Setting-PSI: 16
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=12/25
Burst Pressure-PSI: 275
Max Flow Rate: 11-13 GPM
Nominal Micron Rating: 21
zoom
Part Number: 51372
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.167
