Cracked single stage paint
by JHZR2. 09/18/18 01:45 PM
Options versus dealer oil changes
by Schmoe. 09/18/18 01:34 PM
Longevity of Mercon LV in a 2017 Ford Escape?
by mrdctaylor. 09/18/18 01:24 PM
I'm on a Lawn Boy jag
by andyd. 09/18/18 01:13 PM
Old (New) Tires
by ET16. 09/18/18 12:05 PM
iOs 12 for Apple
by madRiver. 09/18/18 12:01 PM
Synthetic oil overrated??
by Ablebody. 09/18/18 12:01 PM
Ferrari Monza SP 1/2
by DeepFriar. 09/18/18 11:58 AM
Any option to "Mark all forums read"
by Rick505. 09/18/18 11:54 AM
1981 280ZX Turbo
by 16HC. 09/18/18 11:12 AM
Muscle car emblems
by Snagglefoot. 09/18/18 10:15 AM
Burn out question
by Fitter30. 09/18/18 10:15 AM
Collector Oil Cans
by Snagglefoot. 09/18/18 10:06 AM
Thoughts on this truck and price.
by ls1mike. 09/18/18 08:39 AM
Canadian Tire Lucas Synthetic Motorcycle Oil 20w50
by Snagglefoot. 09/18/18 07:58 AM
Blast from my past
by 53' Stude. 09/18/18 07:25 AM
Happy Birthday USAF!
by Astro14. 09/18/18 06:35 AM
Ever had a total engine failure?
by Exhaustgases. 09/18/18 02:58 AM
tomkat22, tabar2004, SierraMan, Rennmeister, KeithCoates
66004 Registered Users
109 registered members (53' Stude, 28oz, 2K2AcuraTL, 2013ecof150, 2010Civic, 12 invisible), 1,712 guests, and 39 spiders.
Topics290,597
Posts4,847,149
Members66,004
Most Online3,590
Jan 24th, 2017
Page 1 of 4 1 2 3 4
75W-85 vs 75W-90 for MTF? #1542734
07/24/09 12:51 PM
07/24/09 12:51 PM
Quebec, Canada
Minou Offline OP
Minou  Offline OP
Quebec, Canada
My owner's manual calls for 75W-85 (API GL-4) MTF but I just flushed that and put Shell Spirax S 75W-90 (API GL-5, MT-1, pour point -45C) synthetic I got from my brother's supply.
The transmission was very stiff (until warmed up) on cold winter days with the OEM stuff. Could it have been dino oil? Is 75W-85 readily available in stores?
The Spirax did great when I put it in my former '05 Corolla. Shifting when cold in the winter was just like in the summer and fast idle speed almost gained 200 RPM.
I hope to improve the cold shifting of my Sonata the same. So far in summer temps, the change is almost unnoticeable.
2016 Ford Edge SEL AWD 3.5l V6
2016 Ski-Doo Grand Touring LE 900
2016 Suzuki Burgman 650
Re: 75W-85 vs 75W-90 for MTF? [Re: Minou] #1542757
07/24/09 01:17 PM
07/24/09 01:17 PM
Afghanistan
Captain_Klink Offline
Afghanistan
redline and amsoil make excellent mtf lite.
in my own tranny, i just mix 50:50 PZ synchromesh with Mobile 1 5w30 EP - both cold weather and hot weather shifting is excellent, 1995 Mitsubishi 5 speed. manual calls for 75w85 gl3.
Re: 75W-85 vs 75W-90 for MTF? [Re: Captain_Klink] #1542889
07/24/09 04:18 PM
07/24/09 04:18 PM
RI
unDummy Offline
unDummy  Offline
RI
75w85 is not readily available in stores. But, any automaker that has a vehicle taking 75w85 will have their version available at the dealers parts department.
I've seen 75w90's that were blends. So, 75w85 should be easy enough to blend without too much 'synth'. Unless it is labelled full synth, it isn't!
Redline MT90 can be thinned with 25%-50% MTL to make your 75w85. I would guess that Amsoil MTG/MTF can be blended the same way.
Hyundai/Kia...just recently stepped down from 90wt to 85wt to improve performance. On cold days, just about any transmission is a little stiff. Both fluids being a 75w, I would not expect a 90wt to shift any better when cold.
Manual transmissions are such a small percentage of the US market, and usually lifetime fill(read your maintenance manual for intervals), that I truly don't expect wallyworld or even the local autoparts stores to stock any, any time soon.
Pretty popular weight overseas.
Those who say it cannot be done, should not interrupt the person doing it.
Your automaker lied!
Is this a spelling/grammar forum or BITOG?
Re: 75W-85 vs 75W-90 for MTF? [Re: unDummy] #1543463
07/25/09 05:50 AM
07/25/09 05:50 AM
Magnolia, TX
INDYMAC Offline
INDYMAC  Offline
Magnolia, TX
You might not want to use GL5 in your tranny. Most GL5's aren't yellow metal friendly.
2013 Toyota Tundra DC 4X4 5.7L FFV
2012 Toyota 4Runner 2WD SR5
2004 Honda S2000
Re: 75W-85 vs 75W-90 for MTF? [Re: INDYMAC] #1543486
07/25/09 07:13 AM
07/25/09 07:13 AM
RI
unDummy Offline
unDummy  Offline
RI
Maybe after a million miles of usage, run underfilled and seriously overheated for an extended time, and after being soaked with water after taking the car submarining.....or combination of the above....
I haven't found a GL5 that WASN'T yellow metal friendly with regular 30k intervals in a normal environment.
If there is no maintenance, you overheat the fluid, and at some point it takes in any water, any fluid can be unfriendly.
Re: 75W-85 vs 75W-90 for MTF? [Re: unDummy] #1543775
07/25/09 12:40 PM
07/25/09 12:40 PM
Chicago Area
mechtech2 Offline
mechtech2  Offline
Chicago Area
Yeah... GL5s are buffered for the last two decades or so.
Since the car in question is in Canada with cool winters, the lighter gear oil would be wise. But normally, it would not make much difference between the two grades mentioned.
Re: 75W-85 vs 75W-90 for MTF? [Re: unDummy] #1543790
07/25/09 12:47 PM
07/25/09 12:47 PM
Flaherty, KY
92saturnsl2 Offline
92saturnsl2  Offline
Flaherty, KY
That attribute of GL5 is real and can destroy transmissions even in short period of time. Different transmissions have varying amount of those metals, but the use of GL-5 will cause wear regardless.
There is a reason the vehicle manufacturer recommend GL-4 for manual transmissions, which most do. If you want your vehicle to last 200k, put the right fluid in. You're playing the lottery when you use GL-5; Odds are against you that the GL-5 will cause premature failure-- Often much sooner than you'd think.
1985 F-250HD 7.5L 4x4 135k- Maxlife 15w-40 HDEO
04 Odyssey EX 182k PUP 0w-40
96 Maxima GLE 250k QS Defy 5w-30
07 Chrysler Pacifica Limited 129k PUP 5w-40
Re: 75W-85 vs 75W-90 for MTF? [Re: Minou] #1543868
07/25/09 01:44 PM
07/25/09 01:44 PM
Ontario, Canada.
7TFord Offline
7TFord  Offline
Ontario, Canada.
Our Toyota Yaris specs either a GL-4 or GL-5 75W-90 lubricant and at first fluid change I put in Chrysler's bottling (#4874459) of Castrol's Syntorq LT, which is a 75W-85/GL-4.
I wasn't pleased with it and had some gear clash in all temps, although stiff winter shifting was not a problem. Have since switched to Amsoil MTG and will be using it from now on.
06 4Runner Sport V8
1970 Mach 1/351C4V
Re: 75W-85 vs 75W-90 for MTF? [Re: Minou] #1544033
07/25/09 05:25 PM
07/25/09 05:25 PM
tampa fl
ravenchris Offline
ravenchris  Offline
tampa fl
Consider RL MTL (GL-4). 2007 Sonata manual, 13K with this product and good results. Local Hyundai Dealer has 75W-85 synthetic.
Re: 75W-85 vs 75W-90 for MTF? [Re: ravenchris] #1544105
07/25/09 07:29 PM
07/25/09 07:29 PM
Alaska
m37charlie Offline
m37charlie  Offline
Alaska
My Unimog calls for 75W-85W of a particular specification, Castrol Syntrans or one of 3 others, none of which are obtainable in the US. I'm thinking about a 50-50 mix of Mobil Synthetic Trans Fluid 50 and MSTF Arctic. Definitely needs a GL4 synthetic, NOT a GL5 since it has synchros. I have 2 gallons of RL MTL for top-off in case I get a leak (it takes 14L). Maybe MTL for complete fluid change?
The owner's manual for North America calls for MSTF 50 but the worldwide Daimler database calls for 75W-85W, so I think 50, even synthetic, is only suitable for warm/hot climates.
Charlie
unimog U500/Unicat camper
05 Unimog U500/Unicat camper/Delvac 1 SHC ACEA E4/E5
09 BMW X5 35d/Delvac1 LE 5W30
88 Toyota OJ50LV OM314 motor D1 SHC
52 Dodge M37/Hercules diesel
Re: 75W-85 vs 75W-90 for MTF? [Re: m37charlie] #1544189
07/25/09 09:01 PM
07/25/09 09:01 PM
tampa fl
ravenchris Offline
ravenchris  Offline
tampa fl
Call RL, sometimes they have the answers.
Re: 75W-85 vs 75W-90 for MTF? [Re: ravenchris] #1544198
07/25/09 09:10 PM
07/25/09 09:10 PM
Dallas,Tx USA
aquariuscsm Online content
aquariuscsm  Online Content
Dallas,Tx USA
If you specifically want a 75W85,swing by any Nissan dealer and get the Nissan 75W85 MTF from their parts dept.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Quaker State Ultimate Durability 5W20
Re: 75W-85 vs 75W-90 for MTF? [Re: aquariuscsm] #1544591
07/26/09 08:50 AM
07/26/09 08:50 AM
RI
unDummy Offline
unDummy  Offline
RI
Nissan, Kia, GM, Dodge, Hyundai, Mitsubishi.....all have 75w85 GL4 fluids available. You can make your own my mixing 25% Redline MTL with 75% Redline MT90 or do the same with Amsoil's MTF/MTG.....
Until someone can show me a GL5 related yellow metal failure not caused by neglect or abuse, it has NEVER happened. BTW, in the hundreds of manuals that I've seen apart, the so-called yellow metal damage wasn't there and many had GL5 gear oil(typical dealer or quicklube bulk oil). This was before the pro-GL4 onslaught and the crybabies who don't know how to shift a manual. We used good ol' incompatible toxic to the manual transmission bulk oil for indefinitely. And, then a couple years ago, the internet created the yellow metal scare.
#*^&% the hearsay!
With 300k miles on one of my 1983 synchronized transmission, it shifted its entire life on Mobil1 GL5 75w90 gear oil with a change out during every 50k clutch job. My only manual transmission failure was caused by 'water' and wasn't saved by the GL4 that I kept it filled with, and the synchros were toast as was the fluid, bearings, bushings, gears and just about anything in contact with the water/oil/rust blob of goop lubricant.
Re: 75W-85 vs 75W-90 for MTF? [Re: unDummy] #1544630
07/26/09 09:47 AM
07/26/09 09:47 AM
Alaska
m37charlie Offline
m37charlie  Offline
Alaska
You needed to change your clutch every 50K miles? In 5-600K miles of manual trans driving, I've never had a clutch wear out.
Charlie
Re: 75W-85 vs 75W-90 for MTF? [Re: m37charlie] #1544828
07/26/09 12:59 PM
07/26/09 12:59 PM
Chicago Area
mechtech2 Offline
mechtech2  Offline
Chicago Area
Since GL4 has approx. 1/2 the sulfur corrosion causing stuff as GL5, why is that not considered a problem?
It is buffered chemically to not be a problem, that's why.
And you need heat and moisture, anyway.
Most GL5s are for hypoid gear protection and they are not good with synchros. That is the real problem.
Page 1 of 4 1 2 3 4
