Originally Posted By: Brian_Bowers
Originally Posted By: SuperBusa
If you put a more restrictive oil filter on the car, and if anytime the pump is not in relief mode, then the output pressure of the pump will be slightly higher to overcome the added resistance of the more resistive filter – but the same positive displacement of oil volume is still going through the filter/engine because the relief valve is still closed. Even though the pump is producing more pressure to move the same volume of oil through a more restrictive path, if the pump’s output pressure is still below the relief setting then you will never see any difference in engine oil pressure – ie, the pressure between the filter and engine where most oil pressure gauge sensors are located.
Try as I might... this won't click for me. If my car makes 40 psi at idle (800 rpms) at 210 degree oil temp why wouldn't a more restrictive filter reduce the pressure registered on the gauge?
Because even if you put a more restrictive oil filter on the car the same volume of oil is reaching and going through the engine. NOW ... if the oil pressure sensor was BEFORE the oil filter then you WOULD see a higher oil pressure there if you used a more restrictive filter. When the pump goes into relief mode, the pressure is constant at the max possible that could be supplied to the filter/engine flow path. If you have a fixed pressure and "unlimited" volume, then if you increase the flow resistance (ie, filter) then the pressure on the backside of the filter would have to be less, which means the INLET pressure to the engine would be less since filter outlet P = engine inlet P.
Here's and example.
Filter A is more restrictive than Filter B. Both have bypass valves set to 15 psi (so they will not be in bypass in the example below).
If the oil pump is in relief at say 80 psi with 5w-30 Mobil 1 at 200 deg F with Filter A installed, then engine oil press = 75 psi on the gauge.
If Filter B is installed and the same conditions are achieved as above, then engine oil press = 70 psi on the gauge.
This means Filter A had a 10 PSID under these conditions, and less restrictive Filter B had a 5 PSID. You could only see this difference in filter resistance IF the pump is in pressure relief, because the filter/engine circuit is going to flow less gpm @ 80 psi supply pressure with Filter A than is Filter B was used instead.
Now, let's do an example with the same Filter A and B above when the pump is NOT in relief mode.
When the oil pump is not in relief mode, then ALL the oil volume coming out of the pump MUST go through the filter/engine flow path.
Look at just the point of flow between the filter and engine ... where the engine pressure sensor is located. Again, the conditions are 5w-30 Mobil 1 at 200 deg F. Let’s say that the engine RPM is at 3000 and the oil pump is NOT in relief mode. Also, this particular oil pump puts out say 6 gpm at 3000 RPM.
Assume that Filter A has 8 PSID with 6 gpm of this oil, and Filter B has a 4 PSID. Also, in order to make 6 gpm go down the engine circuit it takes 70 psi – that would be the gauge pressure at the engine inlet (ie, filter outlet).
So, with the engine at 3000 PRM with this oil there is 6 gpm going through the filter & engine, and the pump is NOT in relief mode.
With Filter A the pump output pressure will be 70 + 8 = 78 psi.
With Filter B the pump output pressure will be 70 + 4 = 74 psi.
But the pump’s relief pressure is 80, so it’s not in relief ... BUT, what happened is that the pump’s output pressure increased due to the more restrictive Filter A. And the key here to note is that the engine’s oil pressure stayed the SAME at 70 psi.
The more restrictive filter just caused the pump’s outlet pressure to run closer to the relief pressure setting. If you ran a more restrictive filter you would never know t his unless you had a pressure sensor BEFORE the filter. Most cars have the oil pressure sensor after the filter (before engine), so they will never see the effect of a more restrictive filter unless the pump is in pressure relief mode.
Hope that makes sense. It’s kind of tricky to see, but once you do it’s easy to understand.
