position the car on ramps, so drain plug is lowest. if plug on back, drive both front wheels up on ramps, if plug on left, drive up right ramp, if plug on right drive up left ramp. Now plug is as low as possible, and much lower than any mechanic would get it.
2. the car should be warm or hot. if hot, wait for it to cool off a bit so u don't burn ur hands.
3. make sure
to put vaseline on hands, so you don't get cancer from the used motor oil, that is just about to soak into ur skin.
with the drain properly positioned, this will ensure max oil will drain out. this is the most important point. second, is not to do it cold. third is to have a cold beer while u wait for oil to drain, it takes about 20 minutes or more, not just the 2 minutes they give it in the quick lube place. afterwards, rub hands with vegetable oil, and clean off with dish soap. that way hands don't smell like engine afterwards, and skin stays healthy.
