20001 Chrysler Sebring 140,000km (currently with TorquePower 5w30 and 10 ounces ARX - Valvoline 5w30 for Rinse phase next)
5,000km OCI (Dealer dino+Filter), Last 20,000 (synthetic + PureOne/Bosch Filters)
Being a sludger, I am about to change the PCV valve (labeled in pic). Reading up on here I decided to check the hosing that connects to the PCV. It has some "gunk", or sludge build up in it, but fairly clear (able to pass a drinking straw thru). Was thinking of replacing the PCV hose and was quoted $58 from the dealer over the phone. Kinda expensive.. maybe I'll just clean it out.
Questions:
1) Bought a Purolator PCV valve.. Should I get an OEM instead? How tight should I tighten it? "till it's snug"? or is there a requirement.
2) A & C in the pic are just rubber hoses. Best way to clean them?
3) B in the pic is a metal tube with a rubber sleeve around it. Attached to it is a wire (2) which clips to engine (1). What is the wire? Best way to clean this metal piece out? Or can I mess something up by cleaning it?
4) D is like a solid nipple where the C hose connects. I could not disconnect the C hose from D, but I didn't try so hard. The D area circled is clean, from possibly oil coming out (but not much). Is this an issue? Can I safely unscrew the one screw that connects D to the engine? Clean it out?
5) All pieces freely disconnected from each other (except C and D). I can just unscrew the old PCV valve, screw in the new valve, and reconnect the cleaned hoses right? Nothing I have to do in between, or in a particular order?
THANKS for any advice and help!
Note: this is not my engine.. just a pic from the internet
[/img]
Questions:
