'03 Hyundai SantaFe, 2.4L engine.
This is the wife's car. We've owned it since Feb. After we purchased it it had a problem where it would loose power and would ocassionally surge/stutter while at idle/low speed. It was determined (by the dealer) to be a coil pack that was failing under load causing misfires. The coil pack was replaced and we haven't had any issues in nearly two months.
It was raining last night and this morning - the car acts up again, same symptoms. Why would humidy cause this? How would humidity cause this? Or, is this most likely a coincidence?
I know humidity can cause problems cause a friend has a Saturn Ion ('04) that doesn't start reliabily when it rains. No problem any other time.
Thanks
Thanks
