Originally Posted By: AEHaas
Originally Posted By: oilyriser
Is cavitation during start up an issue? High viscosity should prevent oil from re-entering the suction region downstream of the load carrying part of the oil film, in a bearing.
Many high revving sports cars sustain engine damage by the user turning the engine on then fully revving it for sound effects. I believe this is a result of cavitation at multiple sites.
aehaas
If it's dead cold but then this practice would be considered abuse. Cavitation can also happen with a fully warm engine if revved too high. I've watched my friend's Porsche lose oil pressure when revved 1,200rpm past the stock limiter fully hot on a 100 degree day.
There's cavitation when the engine is revved too high and the oil is cold and thick but oil pressure can also fall off at very high rpms because the pump can't keep up with the flow requirements.
aehaas
