Capacities about half way down.......
1996 FORD TRUCKS EXPLORER 4.0L 6-cyl Engine Code [X]
FILTERS
Oil Filter: EAO15 Absolute Efficiency Oil Filter:
Oil Filter: 51515 WIX 51515 Oil Filter
Air Filter: EAA416 Absolute Efficiency Air Filter:
Air Filter: 46416 WIX 46416 Air Filter
Fuel Filter: 33296 WIX 33296 Fuel Filter
Trans Filter: 58840 WIX 58840 Auto Tran Filter [1]
Trans Filter: 58841 WIX 58841 Auto Tran Filter [2]
1. 2WD
2. 4WD
NGK PLUGS & WIRE SETS
PLUG GPSERIES TR55GP NGK3403
PLUG IXIRIDIUM TR55IX NGK7164
PLUG PREMIUMPLATINUM PTR5F-11 *
PLUG PRERIUMIRIDIUM ITR5F13 ^
PLUG VPOWER TR55 NGK3951
WIRESET WIRESET RC-FDZ036 NGK52184
TRICO WIPER BLADES
Blade Class Driver Passenger Rear
NEOFORM T16180 T16180
EXACTFIT T181 T181 T122
WINTER T37180 T37180 T37131
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......API*
SAE 0W-30 Synthetic Signature Series Oil
SAE 5W-30 Synthetic Motor Oil
SAE 5W-30 XL Synthetic Motor Oil
All Temps......5W-30
Manual Transmission,.....MA[1]
Synthetic Automatic Transmission Fluid
Torque-Drive™ Synthetic Automatic Transmission Fluid (ATD)
Automatic Transmission,4R55E.....MA
Automatic Transmission,4R70W.....MA
Differential, Front .....GL-5
All Temps......75W-90
Severe Gear 75W-90
SAE 75W-90 Synthetic Gear Lube
Severe Gear 75W-110
Controlled Slip Differential, Rear .....GL-5*[2]
All Temps......80W-90
SAE 80W-90 Synthetic Gear Lube
Severe Gear 75W-90
Severe Gear 75W-110
Standard Differential, Rear .....GL-5
Severe Gear 75W-90
Severe Gear 75W-110
Transfer Case,Warner 1354.....MA
Transfer Case,Warrner 4405.....MA
Fluids
Power Steering Fluid.....MA5
Brake Fluid.....HBH
Series 600 DOT 4 Racing Brake Fluid
Clutch Fluid.....HBH
1. Beginning immediately all manual transmission applications
requiring MERCON can now be serviced using MERCON-V
or MERCON Automatic Transmission Fluid or dual usage fluids
labeled MERCON/MERCON-V. After July 1, 2007,
MERCON Automatic Transmission Fluid will no longer be
manufactured, therefore, availability of this fluid will
only continue for however long it takes to deplete what
remains in inventory.
2. Limited Slip Identification: Letter & number
on plate on door lock pillar. (Models W/ Traction-Lok Rear
Axle Add 4 oz offriction modifier part no. C8AZ-19B546A
(EST-M2C118-A)
CHASSIS LUBRICATION
Two-wheel drive
0-6 Fittings, 0 Plugs..........LM
Series 2000 Synthetic Racing Grease
Synthetic GHD Heavy-Duty EP Grease
Synthetic Multi-Purpose Grease NLGI #2
Four-wheel drive
0-10 Fittings, 0 Plugs..........LM
CAPACITIES
Engine, with filter..........5.0 quarts[1]
Cooling System, Initial Fill..........8.0 quarts
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, 4R70W Initial Fill..........5.0 quarts
Automatic Transmission, 4R55E Initial Fill..........3.0 quarts
Automatic Transmission, Total Fill
4 speed 4wd 4R55E..........9.9 quarts
4 speed 4R70W..........14.0 quarts
4 speed 2wd 4R55E..........9.5 quarts
Manual Transmission, ..........5.5 pints
Differential, Dana 35 Front..........3.6 pints[2]
Differential, Rear..........5.5 pints[3]
Transfer Case,Warner 1354..........2.5 pints
Transfer Case,Warrner 4405..........3.0 pints
1. When refilling, remove dipstick to provide adequate venting
and allow oil to flow into crankcase.
2. Fill no higher than 9.5 mm or 3/8 inch below fill plug.
3. Fill to no more than 1/4 to 9/16 inch below fill plug hole.
TORQUES
Oil Drain Plug.....15-25 ft-lbs
Transfer case
Fill Plug.....14-22 ft-lbs
Drain Plug.....14-22 ft-lbs
Manual Transmission Maz M50D 5-SPD
Fill Plug.....29-43 ft-lbs
Drain Plug.....29-43 ft-lbs
SERVICE INTERVAL
AMSOIL Product Recommendation and Drain Interval Guide (g1490)
OTHER TOP QUALITY PRODUCTS
Mothers® Car Care Appearance Products
By-Pass Oil Filters
PI Performance Improver Gasoline Additive
Copyright ©2008 by MOTOR Information Systems, a division of Hearst Business Media, Inc. All rights reserved.
