I concur; me thinks someone is full of poo ...
A CI-4+ oil has a some different additives, and/or some in higher concentrations, than do the CJ-4 products. However, fundementally, they are very similar. The changes were made for the DPF and cats. And forget not that the fuel was altered, too. That all benefits the emmisions systems. But it has little to do with "sticking" things.
I presume by "stuck pistons" you're inferring stuck piston rings? I highly doubt that CI-4+ would "stick" anything, in this regard.
Besides, let's take away the whole CI-4+ versus CJ-4 issue. Let's presume that one only used CJ-4 in a 6.4L because that's what's required. That STILL does not answer my orignial question to you; why did you list only "synthetic" oils, and not "conventional" oils? With the exception of Amsoil and Schaeffers, there are both a dino and synthetic option for all the other brands you listed. Actually, some have semi-syns as well, but those are rare (except for the Schaeffers). So what gives? Why list only the syns? I agree with you that those products you listed would work well in a 6.4L, but that is true of any engine, because they are all great products. But you seem to be convinced of the "salvation of synthetics". I challenge you to show your proof that other products can't work well in a 6.4L. I challenge you to show proof that 6.4L's are "picky" about lubricant base stock.
I do believe that Ford, GM and Chrysler would all deny warranty if using the wrong fluid, FOR COMPONENTS THAT ARE DIRECTLY EFFECTED BY THE LUBRICANT SELECTED AND IT'S RESULTANT EFFECTS. Emissions-related stuff that failed due to the wrong fuel and/or lubricant being used would rightfully be denied under warranty. However, "stuck pistons" isn't a failure mode associated with CH-4, CI-4, CI-4+, or CJ-4 oils.
"The point is the oil you chose the 6.4 is critical to logevity, performance and smooth operation....they are awesome motors!!!!! " I think what is critical is to choose a lubricant that meets/exceeds the specs set forth by the OEM; show me where Ford spec'd only synthetic fluids!
I personally think it's a bit premature to call the 6.4L an "awesome motor". I'm not saying they suck; I'm just saying there isn't much of a track record to make any real longevity projections yet. Given the spotty record of the 6.0L engines, I'll wait a few years to make any final determination. And don't for a second think you'll suck me into the whole brand-war topic, because while I drive a Dmax, I did work at the Ford steering systems plant in Indy for 16 years. I'm not brand loyal; I'm being realistic.
You said that the 6.4L engines are picky, but to be honest, it sounds like you're the one that's picky. And if the dealership you're at is just as "picky", I'd have concern in that regard as well.
I'm being harsh; I realize that. But you've made some fairly heady claims. I'll give you the opportunity to avail youself; post of the "proof" of picky 6.4L engines. Got any significant UOA results showing where only "synthetics" saved the engine, or where "conventionals" failed? Got any teardown pictures and measurements where the "stuck pistons" would have been saved by synthetic CJ-4?
