The CEL on my '95 Tercel just came on with DTC P0401. The EGR down tube was cleaned by a repair shop a year ago (or about 18K miles ago). They told me that the EGR valve was still good. I have searched the Internet looking for solution. Many suggest to also clean the port on the intake manifold where the EGR down tube connects. I have two questions:
1) The EGR down tube are bent at both ends. Can someone suggest where to find a long and flexible metal brush to clean the carbon inside the tube?
2) I do not want to remove the intake manifold since it is a lot of work. Is it possible just to clean the carbon around the port without removing the intake manifold? Will carbon being scrapped off cause any damage to the engine when it falls into the intake manifold?
