I'm getting ready to install a thicker anti-roll bar under the back of my car, and I'll want to lube the rubber bushings so it doesn't squeak. I've got some no-name high temp disc brake/wheel bearing grease that's who knows how old (probably only 5 years or so though).
Will this be sufficient or is there a different kind of lube you're supposed to use for suspension parts?
