Hey, all,
For various reasons, space being foremost, I'm planning to use jackstands this spring when I change my oil on the Buick. I have two jacks, a scissors jack (a pain in the patoot to use) that came with the car, and a hydraulic scissors jack that I bought some years ago. It says it will lift the car 14", but when its red line came into view, the stop indicator, the car was only about 12" off the ground. That is to say, there's about 12" of clearance from the level ground to the nearest point of the car frame. (Has anybody used a stock GM scissors jack? How high can it get the car?)
Are there jackstands that will fit under there? The Sears Craftsman 3-ton pair I was looking at says its minimum height is 13", but the Torin Double-Lock Jackstands from Northern Tool have a minimum height of just under 11".
Back when I crawled under my cars to change oil, I would just put the front wheel up on a wide curb, but I don't have that luxury now. Any ideas?
