Originally Posted By: G-MAN
Originally Posted By: SKUNKY
Ok..here's a thought...Diesel motors have a hot turbo but they also hold 14/15 qts of oil. HD only has 3/4 qts. Now, run all day in 80° plus weather and then do a UOA......
Well, Harleys actually hold around 3/4 of a gallon, not 3/4 of a quart, but you're right on point. You can't really compare a big rig oil environment (even if we're talking turbocharging), and an oil capacity of several gallons, with the punishment an air cooled TC96 puts an oil through.
I should have said...3 to 4 quarts. depending on the model. I assumed that 3/4 qt meant the same thing. Sorry....
