Matrix totaled
by circuitsmith
06/19/18 08:32 AM
Door rust problems
by Dave Sherman
06/19/18 07:51 AM
2016 Honda Civic problems
by dbias
06/19/18 07:39 AM
Royal purple 75-140 in a subaru rear
by 91camarosRS
06/19/18 07:32 AM
OCI. With short trips. Nissan 4 liter
by Gawardawg
06/19/18 06:52 AM
Approach Watching on the Beach @ St Maarten ...
by LoneRanger
06/19/18 06:41 AM
Honda Accord Needs Shocks; Front, Back, or Both?
by tc1446
06/19/18 05:50 AM
How much oil does your oil filter hold?
by Snagglefoot
06/19/18 05:44 AM
better day
by mx5miata
06/19/18 05:26 AM
BRAVO to Officer Wheeles......
by Sayjac
06/19/18 05:17 AM
People Watching ....Airport style.
by ZZman
06/19/18 04:24 AM
Subaru's at play...
by OneEyeJack
06/19/18 03:50 AM
Treating a 2003 Jetta
by llmercll
06/19/18 01:41 AM
Brakes not working - brake pedal sinks
by tookien
06/19/18 12:42 AM
Dave thinks I can make it 12--15k
by Marco620
06/19/18 12:26 AM
'05 Impala front wheel "squeal". Cost !
by Lee4212
06/19/18 12:16 AM
One Dollar Per Gallon?
by Y_K
06/18/18 11:53 PM
Walmart Tightening up Returns
by John_K
06/18/18 10:21 PM
flare nut wrench set
by spasm3
06/18/18 09:46 PM
Auto trans temperature scanner - help!
by JeffKeryk
06/18/18 09:45 PM
JustaDude, 3horseman, Firedog45, WtsTacoma01, Orion62
65265 Registered Users
84 registered (andyd, BAJA_05, AndyB, 2009Edge, 2004tdigls, ARCOgraphite, 7 invisible), 1499 Guests and 32 Spiders online.
65265 Members
67 Forums
285586 Topics
Page 1 of 2 1 2 >
#1381251 - 02/21/09 01:27 PM VW GTI 1.8T Oil
JAG Offline
Loc: Fredericksburg, VA
New update on my engine/oil issues. I post in this forum because it is a Euro engine and this thread is a continuation of a previous one here: http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=851595&fpart=1
I recently finished a 4800 mile run with Mobil 1 5W-40 Turbo Diesel Truck (CJ-4 version). Well, today I checked the valve cover area and PCV system, and found that the oil let me down. Varnish has again formed in these areas. I did not mean to run the oil this long but it just happened. I meant to go about 3700 miles, which with some other oils (like Amsoil ACD), no varnish formed anywhere.
So, I'm quite annoyed and not impressed with M1 5W-40 TDT CJ-4. It is pathetic that 5000 miles is too much to ask of a modern synthetic oil in a modern VW engine, driven in a normal manner. ACEA should use this engine to test long drain oils...it's an oil-killer.
Red Line 5W-30 is now in the engine. It will be interesting how good this oil does in my engine.
#1381258 - 02/21/09 01:33 PM Re: VW GTI 1.8T Oil [Re: JAG]
jldcol Offline
Loc: ohio
Not a expert, but varnish does not sound that bad. It is thin and will not block oil passages much, and is well stuck so should not move around and clog things. Gooey sludge much worse.IMHO.
Sorry if unclear, I intended to make no sense at all.
#1381262 - 02/21/09 01:38 PM Re: VW GTI 1.8T Oil [Re: jldcol]
simple_gifts Offline
Loc: Middlesex County CT
Just reread portions of the O.T. and it seems to be causing you some understandable angst.
Are you just trying different oils? If ACD is working can't you find refuge there?
2004 Prius; 92K ML Syn 5W-30
2007 Yaris 68K 0w-40 Castrol
2006 B2300;130K;ALM
Was driving an ox cart; Now on the USS Enterprise
#1381266 - 02/21/09 01:42 PM Re: VW GTI 1.8T Oil [Re: simple_gifts]
wavinwayne Offline
Loc: North Alabama
My 1.8T has varnish, always has since I bought it at 15k miles. It now has 134k miles and still runs like a champ. I think we make too much of varnish here.
Silence is golden, but duct tape is silver.
#1381364 - 02/21/09 03:01 PM Re: VW GTI 1.8T Oil [Re: wavinwayne]
JAG Offline
simple gifts, yes I'm trying different oils for various reasons. I bought 65 qts. of M1 5W-40 on sale so that's what got me off of Amsoil ACD. Now that is not so pleasing. Sometime I may go back to using ACD.
jldcol, this varnish is film-like and also contains chunks of larger particles.
wayvinwayne, the 1.8T PCV system has some parts with very small orifices, so it does not take much to clog them. Then it doesn't work and you get all the negatives of not having crankcase ventilation. It is a terrible design. I replaced my once already at a cost of $500 for parts and labor. I won't do it again. If need be I'll run with a clogged system, but I'd attempt some kind of modification that ventilates the crankcase.
These same deposits also tend to cover the inside of the intercooler, reducing its cooling effectiveness. I've already cleaned that mess off of mine once...not pleasant.
#1381406 - 02/21/09 03:56 PM Re: VW GTI 1.8T Oil [Re: JAG]
buster Offline
Loc: NJ
I'm very surprised an oil as good as M1 TDT is not holding up well for you. Are you sure it's the oil JAG? The Redline run should be very interesting. How long until you see results for the RL?
#1381477 - 02/21/09 05:42 PM Re: VW GTI 1.8T Oil [Re: JAG]
bruno Offline
Loc: new Jersey
Why don't you stick to VW 502 approved oils ?
#1381623 - 02/21/09 08:43 PM Re: VW GTI 1.8T Oil [Re: bruno]
JAG Offline
buster, all the maintenance parts on the car that could effect combustion and therefore deposits are not past their replacement date. I don't detect any coolant leak into the oil. So I am blaming the oil.
I probably won't get a good idea of how the Red Line holds up until the 2nd fill of it. This first fill is tainted by the deposits already there.
bruno, I like some VW 502 approved oils and not others. That spec puts the bar above ACEA A3/B3 but not as high as some other specs like MB 229.5. So it's ok but nothing to get excited about. My warranty expired long ago and during that I used VW 502 oils. I had deposit issues in this engine with some of those oils too.
#1381991 - 02/22/09 10:03 AM Re: VW GTI 1.8T Oil [Re: JAG]
buster Offline
Loc: NJ
It should be interesting to see if RL will further clean and remove existing deposits.
#1382206 - 02/22/09 01:22 PM Re: VW GTI 1.8T Oil [Re: buster]
tig1 Offline
Loc: Illinois
That,s strange. I can't recall ever hearing a M1 lubed engine forming varnish like you are describing. Normally M1 keeps engines very clean. Sludge or varnish.
2007 Ford Fusion 227,000 miles
M1 0-20 EP
2017 Ford Fusion 49K
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
#1383381 - 02/23/09 03:24 PM Re: VW GTI 1.8T Oil [Re: tig1]
This seems to be a quality bestowed on RL oil by everyone except the mfg.
It took me several 6-9K runs to achieve maximum TBN retention.
This circumstance may warrant Terry's input.
2006 B2300;130K;ALM
#1390894 - 03/02/09 10:52 PM Re: VW GTI 1.8T Oil [Re: JAG]
Tornado Red Offline
Loc: Saint Paul (ex-San Diego)
I'm sure there are TDI owners in your area who will be happy to take that TDT off your hands.
'03 Golf TDI, 704k miles: Bosio DLC764, GT1749VB, Malone Tuning, G60/VR6, Bilstein HD, Recaros, Akebonos, Brembos, Pirellis, DG Panzer, Delvac 1 ESM 5W40
#4631062 - 01/11/18 05:55 AM Re: VW GTI 1.8T Oil [Re: JAG]
Lada Offline
Loc: Czech republic
Hello, what do you think about use 300V 0W40 in a VW 1.8T Stage 1 (about 155kW)? I have also a small additional oil cooler.
Now I'm using 8100 X-Lite 0W30. But X-Lite is no longer offered in my country. I want some premium oil like 300V, Millers CFS or Redline but Redline is expensive. CFS offers 0W30 (HTHS 3,11) and 5W40. 300V has lager range of weights for my engine - 5W30, 0W40 and 5W40.
#4631067 - 01/11/18 06:10 AM Re: VW GTI 1.8T Oil [Re: Lada]
rooflessVW Offline
Loc: North Carolina
You're grave digging a bit, don't you think? Stick to an oil with 502/A40/229.5/LL01 and you'll be fine. Doesn't have to be a boutique oil.
"Zed's dead baby, Zed's dead."
#4631106 - 01/11/18 07:11 AM Re: VW GTI 1.8T Oil [Re: JAG]
Lada Offline
Loc: Czech republic
I know 502 is sufficient and 300V is "too good" for 1.8T. I like X-Lite with 502 (quieter engine, more stable temperature). But X-Lite is more expensive than 300V and same as CFS, so there is almost no price difference for me.
Edited by Lada (01/11/18 07:15 AM)
Page 1 of 2 1 2 >
