Originally Posted By: toocrazy2yoo
Fair enough. But the product doesn't fail horribly. The cooling system fails horribly, and the negligent owner who never raises the hood and never gets the car looked at doesn't notice the damage over months of accumulating effect and corrosion.
Again, the product DOES fail, and as a result, causes failure of the cooling system. The average owner looks at his fluids and sees that his levels are up to par and knowing in his heart that the engineers that developed his car, which are supposedly much smarter than he is, have developed and tested that 5yr/150k fluid so he wont have to worry. After all, that is what they are paid for, right? You and I are not what is considered 'average' we are anal-retentive about fluids, hence why we are on this site, but the other 99.99% of people who own cars are not. They believe what they are told from the people whom they feel know their car the best----the Mfg.
And I'm obviously the first one to state that a 5yr/150K interval is preposterous. However, with new hoses, and a healthy radiator, maybe the stuff WOULD go that far. But I'd bet there are caveats in the fine print that say the extended interval assumes a healthy cooling system.
As am I, but isn't that what is installed on your new car? I mean, what is the average time before a radiator or hose becomes unhealthy? 2 years? 3 years? 5 years?
No blow-by from intakes, head gaskets, or leaks in the system. They probably expect you to keep the expansion tank topped off, so as to allow no air in the system. But does that mean you put the stuff in and forget it for 5 years? Like I said, the damage "caused" by DexCool wasn't damage that took place in a day, a week, or a month. The damage we're seeing in the pix that "prove" DexCool "caused", was in fact preventable by raising the hood and noticing the puke tank was low. By noticing the crud in the expansion tank. And by taking action against a leaky hose, bad radiator cap, or bad head gasket. I'd say it was bad manufacturing practice to go plastic with intake manifolds, too. With that, the inspection periods should be made more frequent.
As stated earlier, average Joe will check his fluids and follow his owners manual on changes. And not every Dex-cool sludge monster was a result of a low puke-tank. And when he looks in that puke tank, he may see that sludge and figure its just like oil, gets brown alittle from removing that rust in his system, just like oil removes those nasty deposits. but after all, My oil gets dark way before my quicky-lube place's 3K change sticker says, and those highly paid engineers DID say my coolant was good for 5 years and 150K, so all should be good, right?
The kind of damage pictured in these rather shaky testimonials against DexCool and it's clones would have occurred no matter the coolant brand because air simply can't be allowed into the system over time. But the damage does occur over long periods of time and neglect. These things need to be looked at once in a while. There's not a reason in the world the hood can't be raised once a month and the oil, coolant, brake and power steering fluids inspected, especially when the reservoirs are all see-through. A twist on the battery post terminals to see if they're tight, a peek at the belts to see if anything is frayed. Grand total? I dunno, 1 minute, thirty seconds? Gimme a break.
Personally I have never seen green coolant sludge up and engine like Dexcool does, but I understand what your saying here. And I do think most people do just that, they look. Problem is, when your told something should last XX amount of miles or time, you tend not to worry about it as much.
The penalty for a breakdown is too severe not to do a minimal inspection under the hood once a month. Especially for the crew that reads here. Folks that don't read here need to get hubby or a gas station, or the dealer to do it for them. And they neglect these things at their peril. These are common sense issues. And to take the motor oil analogy and compare a 1K OCI vs. a 30K coolant change out is rather specious at best. Synthetic oil (or dino either) won't sludge up in one OCI in normal usage at recommended change intervals unless something is SERIOUSLY wrong, like a plugged PCV, and in one OCI not even that. Sludge is another result of prolonged and profound neglect of the engine and maintenance. You can neglect your car per the letter of the schedule put forth by the manufacturer if you wish, but I think it's been shown over and over, you neglect these things at your peril. New cars are better on many, many levels than those of the 90's and earlier. However, they're still cars, they still burn gasoline, they still need cooling systems, the same fluids course through their lines as 60 years ago, and these things still need inspection and these rules will not change. Again, ignore them at your peril..
Get a hubby or a gas station?? I am sure the women on this site will perk up on that one, and as for Gas stations? Do you know how many full-service gas stations are left anymore? I highly doubt that the attendant at the local Kum-And-Go is gonna check your oil because you don't know how to, or your 'hubby' ain't around.. Add to that the relative 'maintenance free/low maintenance' that vehicles are advertised with today and it only furthers the way of thought. I look at an owners manual today and I see a maintenance schedule that the MFG feels will allow their product to make it to it's useful life, which with new cars most people I think would agree that 150K and 7 years is about average lifespan of a car serviced by that schedule. Fluids are not the same as they were 60 years ago. Yes, oil is still needed, as is coolant, however, each product is light-years better than what was in 1950. In the '50's oil was changed at a max of 1000 miles. It's what the MFG recommended and it gave the lifespan they figured it would. Nowadays I am being told I can go up to 7500 miles, 10K if is a certain VW. Does that mean I am neglectful if I don't change it out at 1K?intervals?
