Shotgun Ammo
by user52165. 12/16/18 10:24 PM
Bought a Model 3 for wifey
by JeffKeryk. 12/16/18 09:01 PM
Maybe I'm crazy.
by TRDPRO85. 12/16/18 07:50 PM
Pacer EON E-11 Synthetic Motor Fluid
by Brandon9797. 12/16/18 07:46 PM
Reuse transmission fluid??
by FFeng7. 12/16/18 07:35 PM
Amsoil SS color change
by BigShug681. 12/16/18 07:21 PM
Why don't owner's manuals specify the oil type
by OilUzer. 12/16/18 07:13 PM
belt tensioner problems
by mobilaltima. 12/16/18 06:57 PM
How bout them Patriots
by 53' Stude. 12/16/18 06:36 PM
Hand held Ham radio suggestions
by littleant. 12/16/18 05:20 PM
Ford 2.3 EB's using 87 vs 91/93 octane
by Whimsey. 12/16/18 04:48 PM
Oil analysis pump tube?
by maximum6. 12/16/18 03:56 PM
Mahle charcoal lined filter..the best!
by TiGeo. 12/16/18 03:45 PM
Diesel engines and emissions
by spasm3. 12/16/18 03:31 PM
Experiment time
by 53' Stude. 12/16/18 02:52 PM
2019 2.7L EB - Edge ST & Catch Can
by -SyN-. 12/16/18 02:51 PM
stantaur, Brandon9797, Landngroove, DanielH, Cpcz9382
66700 Registered Users
65 registered members (1345, bdcardinal, anndel, ABomb369, A310, 8 invisible), 1,480 guests, and 44 spiders.
Topics295,169
Posts4,929,068
Members66,700
Most Online2,553
Oct 27th, 2018
Page 1 of 3 1 2 3
How much residual oil leftover after oil change? #1366890
02/08/09 10:06 AM
02/08/09 10:06 AM
Rochester, MI, US, World
Klutch9 Offline OP
Klutch9  Offline OP
I got to thinking about this the other day. Is there just a thin film left on all surfaces after the oil is drained (and filter replaced too)? I ask because i plan on doing a UOA after my next change, but i used a little ATF in my oil before the last drain, and im wondering if there is enough of it still in my engine to throw my results off just a bit...?
'11 Fusion SE 2.5L - 83k miles - HK 0w20 syn, Wix XP filter
'08 Sedona LX LWB 3.8L - 129k miles - Havoline HM 5w20, Auto7 filter
Re: How much residual oil leftover after oil change? [Re: Klutch9] #1366915
02/08/09 10:28 AM
02/08/09 10:28 AM
Florida, Cape Coral
Eddie Offline
Eddie  Offline
Florida, Cape Coral
0.7 quarts remain in my Mazda turbo (6.7 quart system). Oil remains in the oil cooler and lines + some in the engine. if you change oil brands you should do the UOA on the second oil change. Seems to be true for most engines as shown in UOAs. A different oil seems to need some running in? before setting down on the second oil change.
CX5 Touring 2.5L :-)
Re: How much residual oil leftover after oil change? [Re: Eddie] #1366923
02/08/09 10:37 AM
02/08/09 10:37 AM
Deplorable in apple valley, ca
Chris142 Online content
Chris142  Online Content
Quite a bit I'd think. An old V8 will still have 16 lifters full of oil, every low spot on the heads, oil pump etc.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: How much residual oil leftover after oil change? [Re: Eddie] #1366938
02/08/09 11:00 AM
02/08/09 11:00 AM
Klutch9 Offline OP
Klutch9  Offline OP
ah ok. my problem is i rarely use the same oil twice lol. im pretty satisfied with my current fill, but i think im gonna still mess around with different oils to see which works best with my engine. Im gonna try Rotella 5w-40 synthetic on my next fill, and i think from then on out it'll either be that or Maxlife (what i have now. great for cold starts)
Re: How much residual oil leftover after oil change? [Re: Klutch9] #1366956
02/08/09 11:33 AM
02/08/09 11:33 AM
Phila,PA
rg200amp Offline
rg200amp  Offline
Phila,PA
My LS calls for 6.5 quarts. When I change it (the level stays the same for the whole OCI. No make up oil needed) I have to put in exactly 6.5 quarts to get the level on the upper end of the dipstick.
SO The sump more than likely holds 7 quarts and I can only change 6.5.
// 2013 Subaru WRX //
SOLD:
-11 Volkswagen Jetta
-04 Lincoln LS
-01 Ford F250
-04 Mazda Rx-8
-97 Jeep Wrangler
-97 BMW M3
-97 Nissan Maxima
Re: How much residual oil leftover after oil change? [Re: rg200amp] #1366960
02/08/09 11:37 AM
02/08/09 11:37 AM
Raleigh ,NC CSA
rshaw125 Offline
rshaw125  Offline
Raleigh ,NC CSA
I don't think there is much left unless you don't let it drain very long. I have taken engines apart that the oil was left to drain for a week or so first. Maybe a few ounces remained. If I want a good oil change I leave the drain plug out over night. It has stopped dripping by the time I get back to it.
2012 Porsche Carrera S
2016 Ford Edge 2.0
2002 Taurus Vulcan SOLD
2006 Explorer SOLD
Re: How much residual oil leftover after oil change? [Re: rshaw125] #1366994
02/08/09 12:10 PM
02/08/09 12:10 PM
ontario canada
scoobie Offline
scoobie  Offline
ontario canada
same here, my subaru calls for 4.4l WalMart drained it, and it needed exactly 4.4l to fill to max line. i warm up the engine before an oil change, and if the drain is on one side, i'll drive it up ONE ramp, to tip the car that way. if the drain is on back, i'll drive up TWO ramps, to tip the car back. let it drain for half an hour, and most everything will come out. i didn't open the engine to check, but i find the engine takes what the manual will say, if drained this way.
Re: How much residual oil leftover after oil change? [Re: Klutch9] #1367071
02/08/09 02:01 PM
02/08/09 02:01 PM
The IL
SevenBizzos Offline
SevenBizzos  Offline
The IL
I've gotten probably what seems like a lot (>12oz.) just by lifing the front of the car higher with the jack stand. I'm sure there's more to be found inside the engine...
Re: How much residual oil leftover after oil change? [Re: SevenBizzos] #1367123
02/08/09 03:14 PM
02/08/09 03:14 PM
PA
d00df00d Online content
d00df00d  Online Content
PA
Look in your user manual, in the section where it tells you how much oil you need to do an oil change. There should also be a number for "total capacity" or something. Subtract the oil change number from the total capacity number and that's how much is left in the engine when you drain the sump.
2008 BMW M3
Re: How much residual oil leftover after oil change? [Re: d00df00d] #1367130
02/08/09 03:19 PM
02/08/09 03:19 PM
United States
caveatipse Offline
caveatipse  Offline
United States
Haha I am laughing because my Yaris takes I think 2.9 quarts of oil lol. I am comparing it to soe of these big engines and it seems like so little.
Re: How much residual oil leftover after oil change? [Re: caveatipse] #1367174
02/08/09 03:50 PM
02/08/09 03:50 PM
ontario canada
scoobie Offline
scoobie  Offline
ontario canada
my little dodge colt takes 3.5l, i just make sure it's tipped the right way to get out every last drop. it all drains out in 30 min.
Re: How much residual oil leftover after oil change? [Re: scoobie] #1367178
02/08/09 03:53 PM
02/08/09 03:53 PM
Buffalo, NY
Nickdfresh Offline
Nickdfresh  Offline
Buffalo, NY
I doubt much more than .25 of a QT stays in most modern engines...
Re: How much residual oil leftover after oil change? [Re: Klutch9] #1367231
02/08/09 04:34 PM
02/08/09 04:34 PM
Florida
Saab9000 Offline
Saab9000  Offline
Florida
Why the ATF?
Re: How much residual oil leftover after oil change? [Re: Klutch9] #1367255
02/08/09 04:58 PM
02/08/09 04:58 PM
Vancouver, BC
Liquid_Turbo Offline
Vancouver, BC
For Hondas and Acuras w/ K20As, there is 1.1 quarts residual:
Re: How much residual oil leftover after oil change? [Re: Saab9000] #1367257
02/08/09 05:00 PM
02/08/09 05:00 PM
Nothern USA
labman Offline
labman  Offline
Nothern USA
I think it varies from engine to engine. I know my truck has a huge pool of oil on the top of the head. It also has a section of the oil pan that never drains.
Page 1 of 3 1 2 3
