I have a 12 oz. yellow bottle, of gunk valve medic...What is this stuff?it says, to quiet noisy valves.. is a powerful blend of quick-acting solvents, NOT to be confused with ordinary oil additives. It normally quiets vavle lifters in 5 minutes driving or less.directions.Run engine to normal operating temperature. shut
off engine, pour entire contents of bottle into crankcase and drive immediatly.IF trouble persists, mechanical repair is indicated. Conatains (CAS#) Aliphatic petroleum distillate (68476-34-6), Napthenic petroleum oil mixture(64742-53-6/64742-52-5)USe with adequate ventilation..
IS this stuff an additive you leave in? Or is it actually a flush, intended to be taken out in 15 minutes?
