Originally Posted By: Tribeca
Thanks for the advice/opinions. I live in Colorado, where it can be -20 degrees in winter, and 100 degrees in Summer. I use my Tribeca as a daily driver, probably 20 miles of freeway driving each way with an occasional weekend trip to the mountains. My biggest concern is the abuse it received being a rental car, 24K miles in 10 months! I am assuming it must be mostly freeway, so want to keep the engine clean and well protected from further wear. Being a sucker for oil ads, I have thought about using Valvoline to get the "4x better protection."
I live next door in Utah and the same weather plus going down to Las Vegas and beyond gets the temps well above 110 degrees..
I've done 200k with many motors on yesterdays oils. Today's conventional oils are better than yesterdays syns IMO.
Any SM oil is going to keep the engine clean and protected.
Don't fall for the ads and marketing. If you follow the recommended OCI in the manual you'll be fine with a good oil like Valvoline conventional, Pennzoil YB, Halvoline Ds or any other the other great oils.
As far as it being a rental. I'll be it is cleaner inside than if the normal owner had it. As far as wear, the engine is prob ok and since it is AWD, the power train is better off than the average FWD.
I'd be more concerned with doing a drain, replace the spin on filter on the Automatic. Also get some 75w-110 AMsoil gear lube in the transfer case and rear diff.
Also, when you get to 30k you'll have to replace the coolant, make sure you put in the stop leak from Subaru (they call it a conditioner) as the boxer motors are pretty complex and leak coolant. My 2007 with 24k does.
Take care, Bill
