SWELLING A SEAL
conneaut ohio
GOT A SHRUNK CRANKSEAL ON A 2 CYCLE ENGINE WHAT WILL SWELL IT UP LONGENOUGH TO GET SLED OUT OF FIELD AND INTO GARAGE?
buy a seal swell additve think they sell them for transmissions
BUT it will/may take a few days or longer and normally need to be running to heat to swell seals.
use a thicker oil like a 20/50 to slow leak.
bruce
Got to pull it over 50-60 times to start thinking about hookin a heavy duty drill to the crank it will spit a little with starting fluid
got rearmain seal stopleak works after 100 miles or so said but what mix with 2 cycle oil or gas it's got oil injecters so no premixing
