Originally Posted By: Lon
Many years ago they made (might still make) a black rubber drain plug that looked like a nipple from a babies bottle for stripped oil pan plugs. It came with a green handle tool looked like a dull awl about 2" long. Up near the handle there were two tabs that when you pushed the pointy part of the tool into the black nipple and turned it would grab something inside the rim of the nipple allowing you to pull the plug out. You pushed this thing with the tool into the stripped oil pan drain plug hole, when you pulled it out the nipple part formed a shape like a ball sealing the hole, the thing worked too! When you plugged the tool in and pushed it it would go back to the shape of a nipple and the tabs on the handle would hold it that way so you could then drain the oil.
I had one on a 66 Falcon so the details are a little fuzzy. The plug worked for many years btw.
HTH
Frank D
This sounds like the one it has a washer molded in that looks as though it takes some kind of tool.But was able to remove with a twist and reinstall.Will keep a duct tape tourniquet handy in that handy side body toolbox.Hi.
Im thinking an oversize plug possibly a quick drain and a little JB Weld will do the trick next time.
Lon has explained EXACTLY what you have. They are very good, dependable, substitutions for the original plug. If you have any mechanical aptitude, you can build the removal tool he speaks of with a rounded end metal rod that you cross drill and press/hammer fit a small metal cross bar into (probably too small, but a U-joint needle bearing comes to mind. MUCH better than a cobbled up JB weld mess!
Much better quality fix would be to buy a matching 14mm tap and drain plug. The original 1/2 inch hole, after it's stripped is almost perfect to re-cut to 14mm(remember that your 13mm and 1/2 inch tools ae basically interchangable, 14mm is the obvious step up). Don't remember threads-per-mm, but the correct tap will be easy enough to choose from new drain plugs specs. 14mm drain plugs are almos as common as dirt, only thing more common is still the old 1/2X20 that was OE on your old Ford.
After removal of old rubber plug, while oil is still flowing out, run that new tap up in there, and the oil flow will both lubricate new thread cutting, but also flush cut metal shavings out as you cut. Do it 5-6 times yearly. MOSTLY for DIYers who've screwed the pooch.
Bob
