Found the Ford TSB...
TSB 05-10-1
LIMITED SLIP AXLE CHATTER, SHUDDER, BINDING
SENSATION, OR VIBRATION DURING LOW SPEED
TURNING MANEUVERS—VEHICLES BUILT BEFORE
4/1/2005
Issue: Some 2004-2005 Ranger vehicles may exhibit a chatter, shudder, binding sensation or a vibration during low speed turns. This may be due This may be due to the axle not having the proper amount of friction modifier installed.
SERVICE PROCEDURE
1. Raise and support the vehicle on a hoist.
2. Remove the differential housing cover bolts and drain the axle lubricant from the rear axlehousing.
3. Remove the differential housing cover.
4. Clean the mating surfaces of the rear axle and the differential housing cover.
5. Apply a continuous 1/8 - 3/16" (3-5 mm) bead of sealant to the differential housing cover.
• For 7.5 and 8.8 axles use Clear Silicone Rubber (TA-32)
• For 8.8 High Torque axle use Ultra Silicone (TA-29)
IF POSSIBLE, ALLOW 1 HOUR SEALANT CURE TIME BEFORE ADDING LUBRICANT.
You can run TA-32 in confidence, it sets up very quickly.
TSB 05-10-1
4/1/2005
SERVICE PROCEDURE
