Wix only lists a Courage, Aegis, and Command in the 20hp size.
Courage and Aegis
Part Number: 51348
UPC Number: 765809513488
Principal Application: Various Chrysler/Jeep (82-09), Various GM, Saturn (85-07), Lexus (90-09), Saab (67-09), Suzuki (86-02), Toyota (88-09), Yugo (86-89), Harley-Davidson, Various Lawn&Garden, Farm Equip.
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.404
Outer Diameter Top: 2.921
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=21/37
Burst Pressure-PSI: 275
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 19
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.734 2.430 0.226
Command
Part Number: 51056
UPC Number: 765809510562
Principal Application: Various Lawn & Garden Equip. + Small Tractors w/Hatz, Kawasaki, Kohler, Lister Engines
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 2.707
Thread Size: 3/4-16
Burst Pressure-PSI: 325
Gasket Diameters
..but they appear to be pretty common 3/4-16 thread filters with under a 3" can diameter. You should be able to swap up in size if you have no clearance issues. You can use anything you have room for. Most have 2.8/2.4 gaskets. The main difference is can diameter and can length.
