The car is a 1995 Toyota Tercel (MT, no AC, no PS) with 287K miles on the original engine. I hook up a Scangauge to the OBDII port, so, I can observe the voltage/RPM/MPG/coolant temp while driving. After installing a brand new Odyssey battery PC1200 (a dry cell battery) two days ago I pay speciall attention to the voltage reading since it requires constant voltage to recharge. The voltage remains constant most of the time around 14.1V and occassionally jumps to (no more than) 14.2V during daytime driving.
While driving home from work tonight with headlights (low beam) and fan (at medium speed) on I noticed the voltage dropped from 14.1V to 13.6V when I stopped at a traffic light with the engine idling. To find out the culprit I turned off the headlights and fan respectively. To my surprise it was the fan that drained the voltage which was not even set at the max speed. Once the fan was off the voltage returned to 14.1V at idle with the headlights on. As car was moving the voltage remained at 14.1V even with the fan being turned on.
What could cause the fan to reduce voltage? What can be done to fix this problem? The weather is like winter here now, and I need the fan to circulate heat but without ruining a $240 battery.
