My wife's 06 Chrysler Sebring with the 2.7L V-6 has had a steadily worsening lifter tick for quit some time now. I just recently finished a clean phase of Auto-Rx and now started the rinse phase. The tick progressed from an occasional occurrence after the car had been driven for a long period of time (started about 8 months ago) to ticking at every start up and often ticking during the entire duration of the engine running. During the clean phase, the lifter tick regressed back to every start up ( for about 40 seconds ) and random ticking during operation. ( 1 out of 6 runs ) I changed the oil this past weekend to do the rinse phase and used a SuperTech ST16 oil filter. The ST filter is much smaller than any other manufacture's filter, it's about a half inch shorter. I cranked the car this morning for the first time since the oil change, which so happened to be the coldest morning thus far this season. I was amazed that there was absolutely no tick what so ever. This may be due to the rinse phase
or the smaller oil filter. I wonder if the smaller oil filter increased my oil pressure allowing a slightly stronger flow to charge up that failing lifter. Any thoughts?
