Mobil Delvac 1 ESP 5w40 $23.65 at Walmart
by 71Chevyguy
06/23/18 04:36 PM
diesel oil in older engines- RE: cats etc
by 928
06/23/18 04:35 PM
2011 F-150 Ecoboost timing chain replacement
by 14Accent
06/23/18 04:31 PM
My stash of Kendall GT1 almost gone..
by Vern_in_IL
06/23/18 04:30 PM
mobil 1 rebate check
by Fitter30
06/23/18 03:52 PM
Cab mount failure
by ram_man
06/23/18 03:31 PM
02 Saab aero oil?
by Newuser
06/23/18 03:00 PM
Extend wifi range
by clarkflower
06/23/18 02:05 PM
Under valve cover pics 207,000 miles
by WobblyElvis
06/23/18 01:57 PM
Lease Buyout by Dealer
by Throt
06/23/18 01:52 PM
13 Ford Escape
by RedOak
06/23/18 01:10 PM
New washer pump leaking fluid
by llmercll
06/23/18 12:17 PM
Fuel dilution and CCS/MRV viscosity
by doyall
06/23/18 12:10 PM
Door Hinges
by Scrum67
06/23/18 11:59 AM
PBS, TV channels in different countries
by onetwoothreee
06/23/18 11:29 AM
Break in filter cut open/ Filtermag
by UncleDave
06/23/18 10:36 AM
Changed coil pack, now throwing cat code
by llmercll
06/23/18 10:36 AM
07 V6 Mustang oil leak.
by aquariuscsm
06/23/18 10:33 AM
Windows 10 Update, version 1803
by Sayjac
06/23/18 09:55 AM
Super Tech Euro Spec Synthetic
by Snagglefoot
06/23/18 09:48 AM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
88 registered (2002 Maxima SE, 2015_PSD, 71Chevyguy, 1JZ_E46, 14Accent, 9 invisible), 1533 Guests and 44 Spiders online.
65303 Members
67 Forums
285863 Topics
Page 1 of 2 1 2 >
#1282676 - 11/14/08 02:22 AM Best Grease for Suspesion Components
Burbanite Offline
Loc: North Vancouver BC
I have to replace my Upper & Lower Ball Joints, Idler & Pitmann Arms plus my Inner & Outer Tie Rods. I was wondering what you guys would recommend for a quality long lasting #2 EP GC-LB Synthetic grease. I've looked at RL CV2, Amsoil GHD, Chevron Delo and all I've basically done is confuse myself so I'm sure you grease guru's out there would know of a good product with excellent water washout resistance. These parts are on my 02 2500HD Chevy 4x4. Thanks
#1282711 - 11/14/08 03:59 AM Re: Best Grease for Suspesion Components [Re: Burbanite]
ARB1977 Offline
Loc: North Texas
If you can find a manual take a look in there. There are so many types of grease.
2015 Tacoma 4.0L 60K (as of 02/23/18)
Amsoil SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Factory filter
#1282717 - 11/14/08 04:05 AM Re: Best Grease for Suspesion Components [Re: ARB1977]
The Critic Online   crying
Loc: CA
Moog told me that any high quality chassis grease was fine, but they used to recommend a moly type grease.
The Moog endlinks I bought were prefilled with some type of moly grease, so I'll continue to use Valvoline Moly based grease in mine.
2011 Toyota Prius - 168k - ServicePro Dexos 0W-20
2007 Honda Accord 2.4 - 128K - Idemitsu 5W-20
#1282735 - 11/14/08 05:01 AM Re: Best Grease for Suspesion Components [Re: The Critic]
Johnny Offline
Loc: Retired | Wausau, WI
I really like the Amsoil GHD grease and that is what I'm using on my Jeep. It has all of the moly you need for the automotive/light truck application.
#1282776 - 11/14/08 06:25 AM Re: Best Grease for Suspesion Components [Re: Johnny]
demarpaint Offline
Loc: NY
+1 for the Amsoil GHD grease for front end parts.
Frank D
God Bless Our Troops
#1282961 - 11/14/08 10:52 AM Re: Best Grease for Suspension Components [Re: Burbanite]
Burbanite Offline
So basically a Moly Based grease would be the ticket? It rains a lot up here so I have a concern about water washout. Thanks for the replies.
#1282992 - 11/14/08 11:45 AM Re: Best Grease for Suspension Components [Re: Burbanite]
Johnny Offline
Simple answer yes.
Long answer: The moly is a great EP additive for grease, and the lithium complex base and synthetic oil base works well for your water washout concerns. As I said, I use this grease (the Amsoil GHD) in my Jeep here in Wisconsin for the following reasons, good EP protection, water washout, protection from corrosion due to all the salt we use in the winter, cold and high temp protection.
#1283107 - 11/14/08 02:15 PM Re: Best Grease for Suspension Components [Re: Johnny]
ARB1977 Offline
Loc: North Texas
The only grease fittings i have on my Tacoma is the drive shaft...i use Valvoline synthetic grease on that.
#1286446 - 11/18/08 12:24 PM Re: Best Grease for Suspesion Components [Re: Johnny]
H8SPVMT Offline
Loc: Summerville, SC
Does the Amsoil GHD work well for off road applications like running through mud and water too?
I have a suspension lift kit on my jeep made by Rubincon Express. the joints seem to always need greasing. I'm running a red type lithium grease now.
Edited by H8SPVMT (11/18/08 12:25 PM)
#1286478 - 11/18/08 01:11 PM Re: Best Grease for Suspesion Components [Re: H8SPVMT]
Johnny Offline
Yes, the GHD would be an excellent grease for your application.
#1287347 - 11/19/08 08:29 AM Re: Best Grease for Suspesion Components [Re: Johnny]
H8SPVMT Offline
Then that's what I'll start looking for. Jeep is in the shop for a new control arm mount right now.
Does AZ carry the GHD?
#1287371 - 11/19/08 09:24 AM Re: Best Grease for Suspesion Components [Re: H8SPVMT]
demarpaint Offline
Loc: NY
I seriously doubt you'll find Amsoil GHD in Auto Zone, at least around here you won't. I got mine from Gary Allen with an assortment of Amsoil goodies.
Frank D
#1288393 - 11/20/08 09:47 AM Re: Best Grease for Suspesion Components [Re: H8SPVMT]
gomes512 Offline
Loc: Chicago, IL
H8,
I have used the Amsoil grease for a while before it ran out. Really helped quite down the poly bushings and control arms on my Jeep. Stuff didn't wash out when wheeling in the mud, but I made sure to pump a lil into all the nipples to flush out the grit after a muddin' adventure.
The Schaeffer's moly grease works equally as well.
#1293423 - 11/25/08 06:16 PM Re: Best Grease for Suspesion Components [Re: Burbanite]
Burbanite Offline
Thanks for all the input, Guys, Amsoil GHD will be my weapon of choice.
#1295146 - 11/27/08 11:41 AM Re: Best Grease for Suspesion Components [Re: Burbanite]
wileyE Offline
Loc: Kitsap, WA
Belray waterproof is the only grease that I've found that doesn't washout on my dirtbike rear linkage and head bearings. Had poor luck with anything lithium based, despite being marketed as marine, waterproof, or whatever.
Page 1 of 2 1 2 >
