Cardboard to prevent ice on windshield
by Corollaman - 11/22/19 01:18 PM
Bond Arms Rowdy
by faltic - 11/22/19 01:12 PM
Question about stored vehicles
by loneryder - 11/22/19 12:53 PM
Camry exhaust downpipe
by supton - 11/22/19 12:30 PM
What is your favorite airline and why?
by ZZman - 11/22/19 11:35 AM
Costco Instant rebate for M1
by Joephu - 11/22/19 11:25 AM
Serpentine belt
by Grambo - 11/22/19 10:50 AM
My 2016 Ford Fiesta Failure
by Mr_Luke - 11/22/19 10:37 AM
Starter Tool set - hand tools for professional work?
by btanchors - 11/22/19 10:20 AM
Acceptable amount of time to get up to speed?
by ls1mike - 11/22/19 09:35 AM
Paint question
by supton - 11/22/19 09:31 AM
SUV tires vs passenger car tires
by Ded Mazai - 11/22/19 09:00 AM
Crysler Crossfire Pro/Con?
by tc1446 - 11/22/19 08:54 AM
Possible to balance a bent steel wheel?
by johnnyh55 - 11/22/19 06:33 AM
Tablet question.
by 007 - 11/22/19 04:29 AM
dexos 1 vs dexos 2
by avi1777 - 11/22/19 02:33 AM
I had to lay it down...
by 02SE - 11/22/19 01:22 AM
Costco Car Buying
by rrretiree7 - 11/22/19 01:06 AM
hunter9296, Corslayth, oildud, Kylefl1, JDee71
69938 Registered Users
120 registered members (aquariuscsm, Aero540T, 53' Stude, avi1777, Bailes1992, alteredtuning990, 8 invisible), 2,396 guests, and 26 spiders.
Topics297,779
Posts5,122,370
Members69,938
Most Online3,589
Nov 2nd, 2019
Rate Thread
AC Delco Water Pump, Made in China #1269393 10/29/08 02:24 PM
R
rpn453 Offline OP
R
But it's assembled in the U.S. and has Canadian-made F.A.G. bearings. I was glad to find something with brand name bearings, since it's driven by the timing chain (2.4L Quad4) and the cost of the pump is minor compared to the work to change it. The Cardone reman and new Chinese NAPAs used unmarked bearings.
2004 Mazda3 GT Hatch 75k
Re: AC Delco Water Pump, Made in China [Re: rpn453] #1269416 10/29/08 03:07 PM
c3po Offline
Whay is the year of your vehicle and what kind of vehicle is it.
Re: AC Delco Water Pump, Made in China [Re: c3po] #1269435 10/29/08 03:18 PM
Steve S Offline
It is easier to pollute in China."the forging etc"
Re: AC Delco Water Pump, Made in China [Re: Steve S] #1269503 10/29/08 04:37 PM
R
rpn453 Offline OP
R
It's for a '99 Sunfire GT. 120k miles. Not bad life for a water pump, but I was sure hoping the original pump would last longer. I drain and replace the radiator every 30k with 60/40 Dexcool.
It has been driven about 1200 miles since I noticed the dampness under the water pump, but the reddish fluid was dripping onto the drive shaft right by the transmission seal so I had assumed that the transmission seal was the one that was weeping (there hasn't been enough leakage to drip onto the ground yet). Then the pump started to get noisy and I looked a little closer.
Re: AC Delco Water Pump, Made in China [Re: rpn453] #1269531 10/29/08 05:18 PM
G
GMBoy Offline
G
And worse yet - GM is contemplating selling off AC/Delco.
Re: AC Delco Water Pump, Made in China [Re: GMBoy] #1269673 10/29/08 08:16 PM
Hootbro Offline
My understanding was that AC/DELCO was just a "branding" company nowadays and not really owning any sizable manufacturing concerns.
2020 Jeep Gladiator Rubicon 3.6L (Dealer Bulk 0W-20)
2017 Jeep Renegade Latitude 2.4L (Idemitsu 0W-20)
2013 Volkswagen Jetta 2.5L (Dealer Bulk 5W-40)
Re: AC Delco Water Pump, Made in China [Re: rpn453] #1270044 10/30/08 09:17 AM
O
oldmaninsc Offline
O
120K miles is "not bad life for a water pump"? I've seen some cars that go their entire life with the original water pump. We had several Nissan products in the 80s that went to the junk yard or were sold with over 300K miles on them with the original pump.
I have a Ford sitting in my driveway with over 200K miles on it and the pump has never been changed.
On some of the GM forums, some of the OEM water pumps are making around 50K miles. I have a Trailblazer with less than 50K and the pump needs replaced. The bearings are going bad.
2017 Chevrolet Traverse LT 2013 Chevrolet Impala LT
2005 Toyota Camry LE 2004 Mercury Grand Marquis LS 1998 Ford F-150 XLT
Re: AC Delco Water Pump, Made in China [Re: Hootbro] #1270174 10/30/08 12:07 PM
G
GMBoy Offline
G
That is pretty much true. Even the oil filters are split between Delphi and Champion I believe. Used to be a time I'd go out of my way just for the AC/Delco part, not much anymore accept for some electricl parts.
Re: AC Delco Water Pump, Made in China [Re: oldmaninsc] #1270263 10/30/08 02:20 PM
R
rpn453 Offline OP
R
I would hope that the average water pump does last longer than 120k miles! Really, 10 years and 120k miles on a part isn't good, but it's not that bad, especially as an isolated incident. I've changed the alternator and a muffler strap (twice - must be a sacrificial anode!). Everything else has been routine maintenance.
Re: AC Delco Water Pump, Made in China [Re: rpn453] #1270330 10/30/08 03:13 PM
K
kingrob Offline
K
Never having to replace a waterpump has gone the way of the dodo. Back before the switch to extended life coolants You'd maybe have to do one about every fifteen-twenty years. The last fifteen years or so GM seems to be installing disposable water pumps on their engines. I usually get about seventy thousand miles out of one now. Make sure you get one with a lifetime warranty.
Re: AC Delco Water Pump, Made in China [Re: kingrob] #1270361 10/30/08 03:49 PM
G
GMBoy Offline
G
The first waterpump change (warranty) on my 2006 GMC Sierra Denali pickup (6.0L) happened at 12,000 miles. Waterpumps really have no set written lifespan to predict failure by. I've had them go 200k miles, 70k, and 12k and everything in between. Atleast with hoses/belts/plugs etc you got some idea.
Re: AC Delco Water Pump, Made in China [Re: kingrob] #1270399 10/30/08 05:23 PM
R
rpn453 Offline OP
R
Do you think that extended life coolants such as Dexcool are contributing to the early failures? The other vehicles I service use the standard green stuff, so it would be more convenient in the long run for me to go green on this one too.
Re: AC Delco Water Pump, Made in China [Re: rpn453] #1270428 10/30/08 06:18 PM
K
kingrob Offline
K
Maybe its coincidental, I don't know. I just know that on the older cars that took "conventional" green I never experienced regular water pump failures (or intake gasket leaks, sludged radiators, etc.) I never had to ever replace a radiator until we started getting cheap plastic radiators on our cars, about the same time as Dex-Cool came out.
Maybe it's a combination of cheaper parts and cruddy anti-freeze?
Re: AC Delco Water Pump, Made in China [Re: kingrob] #1270619 10/30/08 11:56 PM
A
AcuraTech Offline
A
Cheaper bearings and seals. Good bearings are hard to find these days.
*The above post is not to be construed as professional advice. For entertainment purposes only.*
Re: AC Delco Water Pump, Made in China [Re: rpn453] #1270674 10/31/08 04:49 AM
M
Merkava_4 Offline
M
I change my Dexcool every 6 months - 50% coolant to 50% distilled water.
