those are all good stock replacement filters with a cellulose media - if you look into a mobil 1 filter they have synthetic medias made of glass fibers. i always stick with OEM filters, under warrenty or not.
i found this in a websearch :
Major brands of automotive oil filters available in the U.S. include FRAM (a Honeywell brand), WIX (an Affinia Group brand), Purolator (a joint venture of MANN+HUMMEL and Bosch), AC Delco (a General Motors brand) and Motorcraft (a Ford Motor Company brand). Some brands, such as Ford's Motorcraft and GM's AC-Delco, are manufactured by other companies (i.e. Purolator for Motorcraft) but are generally designed and quality tested by the brand selling them. Many of the brands manufacture filters for a wide variety of makes and models of vehicles. For instance, Motorcraft sells oil filters that fit GM, Chrysler, Honda, and Toyota vehicles, in addition to Fords. The manufacturer usually provides a list of what makes and models they supply filters for.
Denso is also a major global manufacturer of oil filters as are UFI FILTERS, MANN+HUMMEL, Mahle, Millard Filters and HYDAC who are well known for their industrial grade filters. However KLEENOIL USA is the best in bypass oil filtration.
