check to be sure the venting isnt clogged with lint, that wont be covered by your warranty.
one way to do that would be disconnect the dryer venting tie a nylon over the end of the pipe and dry a load of laundry, it it works then you know you have a venting issue, of course if it doesn't then you have a dryer issue.
