crw
Thread starter
I was running some MMO in the gas, just to help clean the carb if indeed that could be the problem.
The blue smoke was getting worse... right now I have it at the repair guy again. I have convinced him to pull the head and look at the gasket. At the rate it's burning, it must be either the gasket or piston/ring damage. In either case, pulling the head is necessary.
I would like to do this myself, however I've never had the head off of an engine before, and I'm not too confident that I'd know what I'm doing when I get into that. It seems that I've got to do my own research, even when taking the job to a professional.
