Calling all Air Cooled Engine users. Landscapers, Porsche owners, contractors, doesn't matter. I've got a question for you:
I know many air cooled engine manufacturers recommend either a straight 30wt or a 10W30 (synthetic).
I have a 13kw, air cooled, Generac generator that is used for power outages. Manufacturer recommends a 10W30 year round. 2 quart oil capacity with filter.
In my local Kroger grocery store, I scooped up 6 Havoline mineral based 10W40 in the clearance bin for $1/qt. I know Havoline produces some of the best UAO's in a car. But what will happen if I try to use this in my generator year round, here in Michigan?
Background on this generator:
- If I use Mobil 1 10W30 (as most owners do), the generator will run until oil is "consumed" (around 24 hours into a power outage), and the generator will shut itself off with the "low oil level" light glowing. So you need to go out in a 10F icestorm and refill or change oil & filter. Same refill deal on a 85F day (after 20 hours).
- If I use straight 30 wt. It works great (is cheap, & stays in the generator) until winter rolls in. Then you have start up issues.
Questions:
A) Will a 10W40 work as well as a 15W40 HDEO that is commonly used in air cooled engines? (Being cheap to buy, good protection at high temperatures)
B) Will the 10W40 be "pumpable" down to 0F?
C) I know the 10W40 will shear (to a 30 wt - maybe a 20wt?). Will that cause a problem that I would notice longterm?
Questions:
