Originally Posted By: Tempest
Originally Posted By: Kestas
The viscosity specification for each fluid:
6.4 cSt max for Dexron-VI
6.8 cSt min for Mercon V
There is no overlap in viscosity between the two fluids, meaning one fluid cannot be used in place of another, nor can there be a universal fluid that covers both.
This is often quoted in many places as a dis-qualifier, but to say that .4 cSt will disqualify a fluid when the cold specs are at least 10000 cSt is just nuts.
This is also the blend point and does not take into consideration shear in use which can easily go below 6 cSt and those blend points.
DexronIII used to be 7.5 cSt and Dex VI is now 6.4.
If someone wants to talk chemistry or friction characteristics I'll listen, but the viscosity argument is moot.
OH no not this again.......
