Vehicle is a 1999 Freightliner FL70 with a Eaton-Fuller FS6305A transmission.
I checked the oil level this morning by putting in my finger thru the fill hole on the side of the tranny and noticed a lot of foam in the oil on my finger. I tried it three times and found foam each time. The level was within an eight of an inch of the bottom of the fill hole and I added 100ml of oil.
Vehicle had sat for fifteen hours since last driven. Truck has 215k km (135k mi) and the tranny oil was replaced once at 110k km(70k mi). I used Shell Dentax 50 weight synthetic gear oil, approved for this tranny. This was five years ago and I never noticed any foam in the four previous times I checked the oil level (check it yearly).
The tranny leaks a little bit thru the rear seal, enough to contaminate the driveline-mounted parking brake shoes. The leak accounts for the 100 ml needed for topping up.
Why is the oil foaming? Should I replace it?
