Adding fuel filter- Generator built with no filter
by rubberchicken. 09/23/18 09:57 PM
Clutch Engaging too low
by Spetz. 09/23/18 09:41 PM
SMA - Krown previously, Fluid Film Application
by StevieC. 09/23/18 09:21 PM
First Paint Correction
by RayCJ. 09/23/18 08:33 PM
2011 Dodge Caliber
by dogememe. 09/23/18 07:48 PM
Mixing transmission fluids - partial change
by spk2000. 09/23/18 07:31 PM
Counterfeit MANN filter???
by IllinoisSparky. 09/23/18 06:54 PM
The smell of an oil: VME adds?
by fdcg27. 09/23/18 06:48 PM
Classic road brake pads
by buck91. 09/23/18 06:18 PM
Air up your vehicle's tires
by Papa Bear. 09/23/18 06:07 PM
A cool litttle Fall foliage site
by Papa Bear. 09/23/18 06:02 PM
Suggestion: "Likes"
by SnowDrifter. 09/23/18 05:36 PM
Condensation in headlights?
by irv. 09/23/18 05:06 PM
Nissan VQ V-6 Engines
by Al. 09/23/18 04:57 PM
List of dexos licensed oils?
by k1xv. 09/23/18 04:24 PM
High flow oil pump? Thinner oil?
by SnowDrifter. 09/23/18 04:06 PM
Is Tiger back?
by gman2304. 09/23/18 03:51 PM
Lilshady, SevenDu, sigpro, RayCJ, yellow97tt6spd
66055 Registered Users
77 registered members (ammolab, aquariuscsm, 4WD, 69GTX, A310, 3 invisible), 1,328 guests, and 36 spiders.
Topics290,917
Posts4,852,478
Members66,055
Most Online3,590
Jan 24th, 2017
BMW ATF: Texaco ETL 8072-B #1232920
09/09/08 07:07 PM
09/09/08 07:07 PM
CA
gtx510 Offline OP
gtx510  Offline OP
CA
Is there an ATF that's compatiable with Texaco ETL 8072-B?
Think a ETL 7045E ATF would be compatible?
http://www.bmwtips.com/tipsntricks/Tranny/GM2000Chart.jpg
It's for a BMW / GM 5L40-E (or 5150?) tranny.
http://www.bulkpart.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=2&Product_Code=134400
http://en.wikipedia.org/wiki/GM_5L50_transmission
5-speed so it's not a 4L30-E.
http://en.wikipedia.org/wiki/GM_4L30-E_transmission
Could I use Dexron VI in the BMW tranny?
Redline D4 or D6 ATF?
Amsoil universal ATF?
Castrol Import or Domestic ATF?
A Lubegard additive?
And does anyone know if the CTS and BMW tranny filter and gasket are the same?
Thanks
Re: BMW ATF: Texaco ETL 8072-B [Re: gtx510] #1233527
09/10/08 05:51 PM
09/10/08 05:51 PM
CA
gtx510 Offline OP
gtx510  Offline OP
CA
I found a couple ATF's that should work.
I'm guessing M1 M-V or Castrol Import would work the best for an ARX clean/rinse. What do you guys think?
Given the interchange with BMW and multi-vehicle ATF's and how Redline says D4 ATF is compatible with LT-71141, could Redline D4 also be compatible with ETL-8072B?
How about Amsoil ATF?
http://www.castrol.com/liveassets/bp_int...ds_ImportMV.pdf Castrol Import ATF
LA2634, LT71141; Texaco ETL-7045-E, ETL-8027B, Shell M1375.4
What's odd is that I have an older bottle of Castrol import ATF and it only says LA2634 (Shell ATF) and LT71141 (Esso ATF) for BMW.
Do you think they changed the formulation or just the label?
http://www.mobiloil.com/USA-English/MotorOil/Other_Products/Mobil_1_Synthetic_ATF.aspx M1 Synthetic ATF
BMW LA2634, Esso LT 71141, ETL-7045E, ETL-8072B, N402
http://www.mobiloil.com/USA-English/MotorOil/Other_Products/Mobil_Multi-Vehicle_ATF.aspx M1 M-V ATF
http://store.europarts-sd.com/ATFspecguide.pdf Maxlife ATF
They don't say anything about Mercon V being compatible with LT-71141.
http://www.valvoline.com/pages/products/product_detail.asp?product=6
And Valvo's site doesn't mention anything.
http://www.pinnoil.com/pdf/sales/Multi-Vehicle-ATF.pdf Pinnacle Multi-Vehicle / MerconV ATF?
http://www.wynns.com/pdf/ATF_Recommendations_Chart_0208.pdf Wynn's 100% M-V ATF?
ESSO Type LT71141, Shell LA2634, Texaco ETL7045E/8072B, BMW 83229407765
http://www.wynns.com/pdf/Multi-Vehicle_ATF_Sell_Sheet.pdf
7 year / 210,000 mile limited warranty??
Re: BMW ATF: Texaco ETL 8072-B [Re: gtx510] #1234520
09/12/08 07:44 AM
09/12/08 07:44 AM
CA
gtx510 Offline OP
gtx510  Offline OP
CA
No advice?
No one has a BMW with a GM 5-speed auto tranny?
Re: BMW ATF: Texaco ETL 8072-B [Re: gtx510] #1234788
09/12/08 02:43 PM
09/12/08 02:43 PM
Highland, NY
Axe Man Offline
Axe Man  Offline
Highland, NY
Give me the year and model of your BMW. My son is the collision manager for a BMW dealership and I'll ask him what they use for drain/refill/flush.
Re: BMW ATF: Texaco ETL 8072-B [Re: Axe Man] #1234800
09/12/08 02:57 PM
09/12/08 02:57 PM
CA
gtx510 Offline OP
gtx510  Offline OP
CA
2001 530i with a 12/00 build date, green sticker on tranny pan so it should use Texaco ETL-8072B.
BMW only sells in 20L containers, lowest price I've seen is about $300.
Thanks, I'd appreciate any info you could give.
Re: BMW ATF: Texaco ETL 8072-B [Re: gtx510] #1234814
09/12/08 03:26 PM
09/12/08 03:26 PM
Highland, NY
Axe Man Offline
Axe Man  Offline
Highland, NY
I called him and he's checking. He believes they use the 20L bulk containers you mentioned but he'll verify. As soon as he gets back to me I'll post.
Re: BMW ATF: Texaco ETL 8072-B [Re: Axe Man] #1234834
09/12/08 03:54 PM
09/12/08 03:54 PM
Highland, NY
Axe Man Offline
Axe Man  Offline
Highland, NY
OK, got an answer...sort of. In order for my son to be positive as which auto tranny you have he would need to last 7 digits of the VIN. So if you wanna post that or just PM me I'll get back to him.
But here's what he found out so far. If you have the GM tranny it specs either Texaco ETL-7045 or Dextron III. However, he stated that you CANNOT mix the two. If you don't know what's currently in there you have to do a total flush and refill.
Another hooker is that the correct fluid is build date dependent. I gave him the 12/00 build date but to nail it down completely he would need that VIN.
Re: BMW ATF: Texaco ETL 8072-B [Re: gtx510] #1235254
09/13/08 09:01 AM
09/13/08 09:01 AM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
Per GMs 2009 5L40E specs: "The Hydra-Matic 5L40 uses DEXRON® III fluid and is filled for life, requiring no maintenance. The fluid is added at the transmission plant eliminating the chance of contamination at the vehicle assembly sites."
Check here: http://media.gm.com/us/powertrain/en/pro...0_M82_MX5_n.doc
Joel
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: BMW ATF: Texaco ETL 8072-B [Re: JTK] #1235302
09/13/08 10:56 AM
09/13/08 10:56 AM
MI, USA
Whitewolf Offline
Whitewolf  Offline
MI, USA
The 5L40E can also use DEXRON-VI.
My definition of an expert in any field is a person who knows enough about what's really going on to be scared.
~ PJ Plauger
Re: BMW ATF: Texaco ETL 8072-B [Re: Whitewolf] #1235523
09/13/08 08:16 PM
09/13/08 08:16 PM
South Carolina
bmwtechguy Offline
bmwtechguy  Offline
South Carolina
Dex VI would be an upgrade to the original Dex III. I have used Amsoil's universal ATF to service the GM units in BMWs at the advice of my builder and have never had any regrets. He says that's pretty much all he uses these days except on a few of the newest units. It could save you about $5 per liter over the original stuff. The Dex VI would save you even more.
Re: BMW ATF: Texaco ETL 8072-B [Re: bmwtechguy] #1235601
09/14/08 12:10 AM
09/14/08 12:10 AM
Silicon Valley
PandaBear Offline
PandaBear  Offline
Silicon Valley
How can Dex III be a lifetime fill?
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: BMW ATF: Texaco ETL 8072-B [Re: PandaBear] #1235609
09/14/08 12:29 AM
09/14/08 12:29 AM
Las Vegas NV
Tempest Offline
Tempest  Offline
Las Vegas NV
It will just be a short life.
“Never underestimate the difficulty of changing false beliefs by facts.” --- Henry Rosovsky
Re: BMW ATF: Texaco ETL 8072-B [Re: Tempest] #1235710
09/14/08 09:33 AM
09/14/08 09:33 AM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
Yep, "Lifetime" and Strasbourg France made GM units just don't fit together! The (Isuzu/BMW/Cadillac) 4L30E came out of the same plant and was lifetime filled with Dex III. Needless to say, they didn't live much past 75Kmi w/out some drain/fills. With some maintenance, I have seen reports of owners getting close to 200Kmi with them. Not all that many automagics will do that.
Joel
Re: BMW ATF: Texaco ETL 8072-B [Re: Whitewolf] #1609219
09/23/09 08:47 PM
09/23/09 08:47 PM
california
mosearch Offline
mosearch  Offline
california
I was under the impression Dex VI was a lower viscosity spec than Dex III...if so, would it really be an "upgrade" to change-out Dex III for Dex VI in a used transmission?? How does that work?
Re: BMW ATF: Texaco ETL 8072-B [Re: mosearch] #1609514
09/24/09 07:15 AM
09/24/09 07:15 AM
Toronto-ish, Canada
Craig in Canada Offline
Toronto-ish, Canada
Amsoil Universal ATF lists ETL 8072B on its list of applications.
I've recently changed a 2002 540i specing Esso LT71141 to Amsoil ATF (LT71141 also being on its list) and it's like a new car. So far so good.
