Sorry for taking so long to respond!
Originally Posted By: ChiTDI
Were the rear rotors solid and the fronts vented? That may explain a difference in longevity. VWs have that issue, which may explain why the rears wear first. Normally, as mech stated, the rears last twice as long.
Maybe the pads weren't right. Did you have a history of previous brake jobs on the car?
The original pads lasted until 89k. At that time, both the front and rears were replaced with AutoZone Duralast Gold pads. The front rotors are vented I believe and the rears are solid.
Originally Posted By: Tosh
Originally Posted By: doitmyself
Could there be a problem with the emergency brake mechanism?
My first thought, too (well, after I thought 'Old Saturns have rear discs?'). Do the rear wheels spin freely when you jack it up? Otherwise it must be a bum batch of pads. Either way, I don't think you should mix compounds front to rear.
I think this might be the problem. I do get a slight pad drag if I turned the rotors by hand. I know that this is normal for drum brakes, but I guess it isn’t for rear disc brakes with this type of caliper design? I’ll have to adjust the parking brake assembly and report back. I hadn't thought of this as the problem as I thought that such a condition would cause the rotors to show signs of overheating, but they do not.
Thanks!
