M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
79 registered members (Aichiguy, 928, AndyB, AlaskaMike, ammolab, Alfred_B, 9 invisible), 1,567 guests, and 58 spiders.
Topics286,168
Posts4,903,476
Members67,572
Most Online2,967
Mar 10th, 2019
2006 Honda S2000 MTF Analysis UOA #1222558
08/23/08 02:50 PM
08/23/08 02:50 PM
Calgary, Alberta
NorWest5 Offline OP
NorWest5  Offline OP
Calgary, Alberta
Manual Transmission Fluid – Factory Fill
Vehicle: 2006 Honda S2000
Date: August 3, 2008
Mileage/Time: 24 Months, 6,800 miles on vehicle
Total Vehicle Mileage: 6,800 miles on factory fill
(replaced with current version Honda MTF)
V40= 39.8 cSt
V100= 8.6 cSt
Ag 0
Al 17
B 2
Ba 38
Ca 2410
Cr 1
Cu 39
Fe 46
K 0
Mg 4
Mn 4
PB 20
Ni 3
Na 7
P 1030
Pb 20
Si 78
Sn 0
Zn 1128
NorWest5
Re: 2006 Honda S2000 MTF Analysis UOA [Re: NorWest5] #1222597
08/23/08 04:16 PM
08/23/08 04:16 PM
Magnolia, TX
INDYMAC Offline
INDYMAC  Offline
Magnolia, TX
Thanks for posting this UOA. Do you know if this is the new or old MTF? It's very thin (viscosity). When I changed mine a couple of months ago, it was leaking out of the metal hand pump all over my arm. I didn't shake the first bottle, and found the first part I poured was very clear, and then the rest was reddish in color. I gave the second bottle a good shake.
I'm very impressed with the new MTF though. It's a major upgrade IMO.
2013 Toyota Tundra DC 4X4 5.7L FFV
2012 Toyota 4Runner 2WD SR5
2004 Honda S2000
Re: 2006 Honda S2000 MTF Analysis UOA [Re: INDYMAC] #1222609
08/23/08 04:43 PM
08/23/08 04:43 PM
Calgary, Alberta
NorWest5 Offline OP
NorWest5  Offline OP
Calgary, Alberta
I don't know which fluid Honda used for their factory fill. The new fluid seem to arrive at dealerships several months after the end of the 2006 model year. Replacement fluid was purchased by me last summer and I made sure that I got the new label fluid. Both the used fluid and the new fluid seem near to 10w-30 or 10W-40 motor oil. Perhaps semi-synthetic.
NorWest5
Re: 2006 Honda S2000 MTF Analysis UOA [Re: NorWest5] #1222855
08/24/08 06:11 AM
08/24/08 06:11 AM
Magnolia, TX
INDYMAC Offline
INDYMAC  Offline
Magnolia, TX
Actually, your UOA shows it to be SAE 20 crankcase/SAE 80 gear oil.
That leads me to believe it is the new stuff.
2004 Honda S2000
Re: 2006 Honda S2000 MTF Analysis UOA [Re: INDYMAC] #1336354
01/09/09 03:15 PM
01/09/09 03:15 PM
Burlington, Ontario, Canada
CATERHAM Offline
CATERHAM  Offline
I'm running the old stuff in my Super 7 (type 9, German ford gearbox) which a friend who works for a Honda dealer gave me.
Before using it I had severe syncro' problems once the gearbox got hot on the track....could not avoid beating the syncros when down shifting. Don't know what was in their originally...likely some 80W
dino gearlube, but the oil change completely solved my shifting problem. Have 10,000 miles on the oil now. Original oil only had 15,000 miles on it.
-'74 Lotus Europa, 5W-50 & VSOT
-'96 BMW 328i, 50/50 TGMO 0W-20/M1 0W-40
-'94 Caterham 7, FUCHS 0W-20
-'18 Tesla Model 3 - FF diff' oil
