I have a 93 F-250 with 250K miles. The trans is starting to get a little loose and the syncros (I think) are starting to whine in 4th and 5th. The fluid was changed 10K miles ago and I'm going to change it again before I tow a heavy trailer cross country. I was thinking of adding synthetic Lucas oil stabilizer to the ATF to thicken it up a little but then I saw the demo about additives on Bostheoilguy.com and started wondering if adding Lucas would be best. I was worried about heat build up from the air bubbles with Lucas. I was wondering if some other additive would work better or just using straight ATF would be best. I know very little about the differences between ATF's brands inside a manual tranny. Any help would be appreciated.
