As the title says, I have a 2005 Class A motorhome with a Chevy 8.1L Vortec in a Workhorse chassis. This vehicle will see mostly trips in the 100 to 300 mile range, but will be sitting most of the time between camping trips. I have no plans to drive it in winter weather. I will probably winterize it and pull the batteries and put them on a Battery Minder in the shop for the winter. So, driving conditions will be the deserts and mountains of Utah and the adjoining states, from about April through October. Temperature ranges will be about 40 degrees to just over 100 degrees F.
What oil would be best for this sort of use? Annual mileage will probably only be a few thousand miles, but there won't be any really short trips either.
Thanks!
Mark N
Thanks!
Mark N
