Never used A747, as twenty years ago we used R30 in karts as it supposedly gave slightly more power than the semi-synthetic A747 and the head was frequently lifted for inspection anyway, so carbon build up could be controlled.
I think you will get more deposits with A747 than the 800 2T which is a mix of esters (not castor). I've seen reports claiming that A747 is roughly 30% castor (admittedly off the 'net, so take it for what it's worth).
If you think you'll be pulling the head fairly frequently it wouldn't be a problem, but if it is going to hopefully be together for a while, I'd be thinking 800 2T or Silkolene Pro 2 SX
FWIW, the local KTM factory team use Motul 800 2T @ 40:1.
Most kart racers here now use elf HTX 909 which is heavily castor based and good for 25,000RPM, whereas the elf MX oil is HTX 976, a full synthetic (good for 18,000 RPM) is claimed by elf to be cleaner burning than the HTX 909.
