When the problem occurs, is the rev limit exactly 3,000 rpms or does it vary? If it varies then it could be any of the ideas mentioned previously but if it is exactly 3,000 rpms, then that does sound like some form of rev limiter kicking in when it's not needed. How is the engine power up to that 3,000 rpm range when you're driving. Does it feel weak or does it feel normal and then the engine cuts out at 3,000rpm?
FWIW, I had a '96 Olds Cutlass with the 3.4L Twin Cam engine. It had a neutral rev limiter at 4,000rpm. Engine would just cut out at that point. I guess to protect from accidental full throttle reving or high rev neutral drops into gear. The redline on that engine was in the 6,500 rpm range.
Ed B.
Ed B.
