vehicle:
1999 suburban,5. 7,4x4
Driving today Engine will not allow me to get above 3000rpm casuing the truck to slow down. . I placed it in neutral and it still would not allow me to get above 3000rpm. . It sputters when I floor it.I dont think its a tranny problem since it happens in neutral.
Note when I turn off the ignition and restart it goes back to normal driving, but will act up again a 5-10 miles down the road nd allows me to ge the rpm up to 5500-6000rpm like it should be doing.
Also truck has newer plugs, wires, and fuel pump and filter. . . Unsure if it has a new distibutor cap or not.
Could this be a oxygen sensor or catalytic converter, or a egr valve, or____________?
Note: I reset the Check Engine light a few days ago light by disconnecting the battery for 20 minutes, and no new codes have popped up today. .
Any help would be great. .
