I got a small leak from the coolant expansion tank on a Dodge Ram. Its around the plastic that the rad cap sits but it is not the rad cap which is leaking or the rad cap's seal. The hole is in the actual plastic tank. Tried some jb weld but it started leaking again.
Is this something that needs to be addressed right away? Can this small pressure leak cause the vehicle to overheat?
