Hi all, I had a heat shield on my '99 Civic (hatchback) that cracked around one of the fasteners. I removed it because it was making an annoying noise. The heat shield I removed ran under the oil pan and I realized a couple of weeks ago that removing it may not have been the brightest idea so I've bought one off a wrecked '99 Civic to replace the one I removed. The trouble is that it too is cracked around one of the fasteners and I'm pretty sure that if I install it, it's going to make noise. Since I don't have any welding equipment, I can't simply join the metal back together so I'm thinking I may just use a wide washer to clamp the area and hopefully keep it from vibrating.
Anybody fix an issue like this?
Thanks
Greg
Thanks
Greg
