Ok, I recently posted that I've got 82K miles on my F150 and I haven't changed the trans fluid before.
I've got 14qts of Valvoline full syn Mercon V and a new filter for the 3.5 inch pan. Pan is stamped "comes with a reusable gasket".
When I drop the pan, should I expect to see 14 qts drain from the pan?
Is there an easy way to catch all 14 qts?
Should I attempt to drain the torque converter?
Where do I refill the trans fluid at? Under the hood where I check the level?
Thanks guys. Sorry so many questions.
