2004 Nissan Sentra 1.8L
Lab: Oil Analyzer's Inc.
Oil: Amsoil 5w-30
Oil Filter: EAO13
Sump Capacity: 2.9 quarts (I added all 3 quarts)
Oil Miles/Time: 4,292 miles/1.5 years
Total Miles: 31792
No make up oil added, no filter changes.
Oil was changed.
Iron - 6
Chromium - 1
Lead - 92
Copper - 9
Tin - 2
Aluminum - 7
Nickel - 0
Silver - 0
Manganese - 0
Silicon - 30
Boron - 321
Sodium - 0
Magnesium - 0
Clacium - 3572
Barium - 0
Phosphorus - 746
Zinc - 864
Molybdenum - 49
Titanium - 0
Vanadium - 0
Cadmium - 0
Glycol - 0
Water - < .05%
Fuel - < 1%
Visocity 100 C - 10.3
Oxidation - 3.3%
Nitration - 18.6%
TBN - 10.8
Fuel additives - FP3000 at recommended dosage.
This was the first Amsoil oil change on my wife's Nissan Sentra. I purchased this 5w-30 in July of 2006, which was around the time for the SM re-formulation. It was using the older Amsoil packaging, but I was informed that Amsoil will use up all old labels even when the formulation has changed. So based on that, the viscosity barely changed if it was the SM formula.
As with my car's UOA's, and previous UOA's of this engine, lead is high, most likely due to fuel. Silicon was the only issue OAI saw, and I will be checking the air filter housing. It has an EA air filter installed, which is not dirty, but is in need of being serviced, as it's been 1.5 years since I installed it.
I replaced the spark plugs about halfway through the OCI. Other than that, and a belt replacement, no engine work was done. The oil in there now is the oil from the same 6 quart batch I purchased back in 2006. Overall I feel this analysis is rather good, given the lead is coming from lead contaminated fuel.
All comments are welcome.
Oil: Amsoil 5w-30
Oil Filter: EAO13
Total Miles: 31792
Oil was changed.
Iron - 6
Chromium - 1
Lead - 92
Copper - 9
Tin - 2
Aluminum - 7
Nickel - 0
Silver - 0
Manganese - 0
Silicon - 30
Boron - 321
Sodium - 0
Magnesium - 0
Clacium - 3572
Barium - 0
Phosphorus - 746
Zinc - 864
Molybdenum - 49
Titanium - 0
Vanadium - 0
Cadmium - 0
Glycol - 0
Water - < .05%
Fuel - < 1%
Oxidation - 3.3%
Nitration - 18.6%
TBN - 10.8
