whenever I have the blower on in the car, instead of switched to off, the AC compressor will cycle on and off about every 20-30 seconds. It does not matter if the led on the AC button is illuminated, nor the led for exterior air or recycle air is pressed, nor whether the temp knob is full hot or full cold, nor whatever the vent selector is set to. I can have it set on feet only full hot and the AC compressor will cycle.
The only time the AC compressor will not turn on is if I have the blower knob turned to off, so no air is being blown into the car.
Is this normal?
2005 nissan altima, 2.5
Is this normal?
