I've done lots of searching and read hundreds of posts on here but haven't really found exactly what I'm looking for. Seems like I can't find anybody on here in the same situation as me. People on here are daily driving modern cars with roller cams, and then there are people with older flat flat tappet V8's that get raced and rarely or never driven on the street. My car is parked for 5 months of the winter when the snow flies but in the spring, summer and fall it gets driven over an hour a day every day mostly country driving at 50-60mph. My car has the factory flat tappet cam, which should mean it requires an oil with higher ZDDP levels, but it wouldn't be as bad as an engine built for performance cause it's a low lift cam with low valve spring pressures, only meant for turning 5000rpm max. I race the car at the 1/4 mile track once every couple months but being a 200hp engine it's not going to be that hard on the oil even when racing. I know I don't want an all out racing oil for a car that sees mainly highway driving, but I don't want to use a cheap dino oil. I have no idea how many miles are on the engine and I need to get quite a few more out of it before I can afford to build my performance engine (a 455 Olds), so I want to use whatever is best for it. I've been running synthetic 0W40 HDEO as well as Valvoline Maxlife synthetic 10w30. I notice no real difference in the way the car runs although it seems to have a little bit of a lifter or rocker arm tap with the HDEO that the Maxlife didn't have, it could just be imagining it though. Anyways, hoping I can get some good advice/opinions on what oil to run to keep this Olds runnin forever. Thanks.
