Originally Posted By: mudsling
what about if I mix,say 42:1 with a dash of castor oil.The leaner the mix more HP but as you know more wear on piston,rings.I think less heat??.Will the castor clog the reed valve??.I want all HP I can get for at least 10-12 hours of engine ring life.Thanks
You could do that too. It's up to you - I don't know your engine, the tuning, etc.
I do disagree with "The leaner the mix more HP..." I wish it was that simple....some engines - in particular race engines need that extra oil for better piston seal so actually the more oil, the more HP! Try your current ratio with the 1 oz of castor - you might be pleasantly surprized. Won't hurt your reed valve. Where are you getting the Castor oil?
