Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
Is this a battery issue or starter issue or ?
by simple_gifts. 03/18/19 06:24 PM
f250 - Friction modifier needed... which brand
by NattyBoh. 03/18/19 05:35 PM
Michelin's New All-Weather Tire for HD Pickups
by SubLGT. 03/18/19 04:36 PM
Interesting FaceBook argument
by ad_infinitum. 03/18/19 04:36 PM
2000 Silverado Power Steering Pump
by Gito. 03/18/19 04:35 PM
New Full Synthetic Oil from Dollar General
by TheLawnRanger. 03/18/19 04:31 PM
Supertech VS Redline - Project Farm
by StevieC. 03/18/19 03:01 PM
How to fix swollen deckwood
by RazorsEdge. 03/18/19 01:52 PM
Which is more important: Oil or Filter?
by RDY4WAR. 03/18/19 01:45 PM
Dishonest car dealership?
by aquariuscsm. 03/18/19 01:21 PM
Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
MadMikesMech, Indyfordfan, toplscuda, swrve, TomRx
67549 Registered Users
114 registered members (2K2AcuraTL, 2010Civic, 853okg, ABerns, 92saturnsl2, 12 invisible), 2,194 guests, and 68 spiders.
Topics286,025
Posts4,901,081
Members67,549
Most Online2,967
Mar 10th, 2019
Page 2 of 2 1 2
Re: Cheat sheet for newbies reading UOA's [Re: TucsonDon] #1811156
03/10/10 07:55 AM
03/10/10 07:55 AM
Bolivia
widman Offline
widman  Offline
Bolivia
Boron is basically an anti-oxidant Has some anti-wear in different cases. You won't see a decent group I oil without it, but it can often be left out of group II, group III, or traditional synthetics.
Here is one of the most complete wear metals charts I've seen in a while
Wear Metals guide in PDF
Re: Cheat sheet for newbies reading UOA's [Re: widman] #1852888
04/11/10 07:42 AM
04/11/10 07:42 AM
Tn.
CourierDriver Offline
Tn.
I like the report, Im gonna get a degree in chemistry someday. Im glad someone out there knows how to make all those elements stay together for 500k miles. Me, I just want it to run right, bottom line. amen
Look into Forks Over Knives Official Plant-Based Group if you want to change your way of eating.
Re: Cheat sheet for newbies reading UOA's [Re: CourierDriver] #1853472
04/11/10 05:38 PM
04/11/10 05:38 PM
East of IGO
Steve S Offline
Steve S  Offline
East of IGO
Why do people post I want the best for my car,,, When there isn't anything that is the best on the car to begin with.
Re: Cheat sheet for newbies reading UOA's [Re: Steve S] #1897854
05/20/10 06:07 PM
05/20/10 06:07 PM
Bolivia
widman Offline
widman  Offline
Bolivia
One more thing. A lot more engines are being assembled these days with Moly rings. Ring wear will show up as or with the moly that might be used as an antiwear/antioxidant.
Condemnation limits vary per engine and engine construction. Those that are published (CAT, Cummins, Detroit, etc.) are extremely high and not close to what is obtainable.
Re: Cheat sheet for newbies reading UOA's [Re: Bambam] #2333676
07/31/11 10:06 PM
07/31/11 10:06 PM
Spring Hill, FL
sm00thpapa Offline
sm00thpapa  Offline
Spring Hill, FL
This is not bad but what about what the numbers mean? I mean is a high number or low number better for each category?
16 Sonata Sport
16 Elantra SE
09 FZ6R
04 Ascender
96 Cavalier
Re: Cheat sheet for newbies reading UOA's [Re: TucsonDon] #2389160
09/27/11 07:42 AM
09/27/11 07:42 AM
Ponte Vedra Beach, FL
mongo161 Offline
mongo161  Offline
Originally Posted By: TucsonDon
I think Boron is becoming part of the additive pack of some oils ... Rotella CJ-4 comes to mind as having increased the Boron.
+1 After looking at some VOA results on different oils, PCMO and Diesel, BORON is becoming more of an additive in Synthetic and Dino oils.
I get by with a little help from my friends....listen with your eyes....it's the ONLY way to believe what you hear...
Re: Cheat sheet for newbies reading UOA's [Re: Bambam] #2658196
06/19/12 12:34 AM
06/19/12 12:34 AM
Honduras
ARHND Offline
ARHND  Offline
Honduras
How about the different tolerances of each equipment. All factories have their own, so, to be sure of each UOA you should also know the different allowances or minimuns.
Re: Cheat sheet for newbies reading UOA's [Re: RWEST] #2757895
09/29/12 08:48 AM
09/29/12 08:48 AM
Tettnang, Baden-Wurttemberg, G...
skyship Offline
skyship  Offline
Originally Posted By: RWEST
So, to help out an oil-dork, what should the numbers be for a multi-vis, say, RTS 5-40? confused
Blackstones will give averages for most engine types for you to compare results to. For a 1.9 TD I would not be too concerned until the Iron was over 50 ppm, Aluminium over 10, Chrome or Lead over 5 and Silicon from the air filter over 20.
The 5W/40 figures for a UOA are as follows:
SUS Vis at 210F: 66 - 78
cSt Vis at 100C: 11.9 - 15.3
Flash in F: > 410
Fuel % < 2
Antifreeze: 0
Water% < 0.1
Insolubles: < 0.8
TBN: > 1 (Normal) >3 (Severe service)
The trend is as important as the actual figures for wear metals, as every engine is subject to different use and to complicate matters you might have a temporary particle streak occur and rebuilt or new engines produce different figures.
The car should be driven at normal speeds for half an hour plus before draining the oil and the sample taken mid stream into a clean container.
Re: Cheat sheet for newbies reading UOA's [Re: widman] #4490527
08/16/17 08:21 PM
08/16/17 08:21 PM
SouthernCaliforniaDesert,USA
PalmSpringsSCal Offline
link is gone.
Re: Cheat sheet for newbies reading UOA's [Re: Steve S] #4490528
08/16/17 08:21 PM
08/16/17 08:21 PM
Link NA
Page 2 of 2 1 2
