My 92 LS 400 with 200K miles appears to have a slipping tranny. It is not at the stage where the rpm climb does not correlate with speed. But I can sense that it is slipping.
My question, what is the best way to get max life out of a possible dying tranny.
1)Change transmission fluid (it uses Type IV Toyota ATF) every 3K when I change oil (no problem as it takes 2 quarts and is really easy to change)
2)I guess keep rpm low? Someone told me high RPM,especially full throttle gear changes at high rpm kills the transmission.
3)Should I take it off overdrive when in the city (I do mostly city driving).
How about some AutoRx for the transmission?
I figure that if I keep my fluid clean and not push it, it might keep the temp down (just in case it is slipping) and the constant change of ATF fluid will replenish whatever is lost in the higher temperature operating env.
Any advice is appreciated.
