I've used mainly synthetic oils for the last 40k miles and the oil usually does not begin to darken for about 2-3k miles then it gradual darkens until I change the oil at about 5-6k miles. Because of this I consider my engine to be pretty clean internally even though I can only see thru oil filler(clean shiny metal inside). I used Maxlife blend 5w20 for the 1st time and within 1k miles I noticed the oil was as dark as my previous synthetic oil would be at 5k miles, and by the time I drained the maxlife at 4k miles it was as black as Seal (the singer). My question is does this oil naturally turn dark faster or is it cleaning my already clean engine.
